Tires
I am looking at putting a 3 inch lift on my '86 K5, and was wondering what sort of tires some of you guys are running with the same lift. I was thinking about some 35" BFG's, but the 3" lift kit says it can fit up to 33" tires.
Thanks for any/all input. Grant |
Re: Tires
Yep, 35's might fit on a 3" lift, but will likely rub w/o any fender trimming. Most 4" lifts say they'll work with 35" tires.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
Re: Tires
Thanks for the reply, I may have to consider a 4" then, or just modify the fenders till it does not rub. It has a 305 in it now, plans are to eventually put a 383 into it so there will still be room in the engine bay.
![]() Join Date: Dec 2010
Re: Tires
I agree with psycho. You can run 35's but expect some rub while turning. 33's are perfect for that lift. Another inch would solve your problems if you want 35's to clear.
Posted via Mobile Device |
Chevys Kick A$$
Re: Tires
Yea I would do 33's with that and 4" lift would fit 35"s way better!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Re: Tires
I might be growing 4" inches this summer then
![]() Grant |
Chevys Kick A$$
Re: Tires
Sweet if you can I would better to have more lift then not enough! Tuff countrys not to bad I have ran Skyjacker as well and really liked them I had there 4" and 6" lift kits both with blocks in the rear. Very happy with both
![]() Posted via Mobile Device
![]() Last edited by Hoods69BadBowTie; 04-07-2011 at 10:12 PM. |
Re: Tires
heres my 83 with a 91 grill...4" lift and 35's i had to trim the front fenders very little you cant even tell unless i pointed out
Chevys Kick A$$
Re: Tires
Damn sweet looking Burb. Looks great with the lift and tires
