Old 03-23-2003, 10:52 PM   #1
Mountain Man
Need help identifying tranny leak
Have some tranny fluid dripping on the garage floor. Changed pan and filter a week ago, as well as engine pan, in hopes of eliminating all leaks.
Still have tranny fluid, but not coming from pan.
Appears to be dripping from the area at the back of engine.
It is possible for a torque converter to leak, or do you think it is possibly an input shaft seal. Leak seems to trickle down by the flex plate area.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 03-23-2003, 11:27 PM   #2
woodrow59
OzarkHillbilly in Atlanta
Just a thought, have you checked the cooling lines to the radiator. Mine has a leak in the line right where it starts to come up to the radiator but the fluid goes back down the borrom of the line to make it look like the leak is coming from back there.
Again just something else to check out.
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 03-24-2003, 02:08 AM   #3
COBALT
COBALT's Avatar
Either the front seal or a leak around one of your front pump bolts. It can run over your torque converter, and when you fire up the truck the fluid gets flung all over the flex plate. You've obviously popped the inspection cover. What did the front of the pump look like? Front seal leaks are generally easy to identify.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-24-2003, 04:37 AM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
What about the dipstick seal? That one was a MAJOR pain on my 700R4...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
