Old 04-07-2011, 11:22 PM   #1
trapperjack
trapperjack's Avatar
Front bumper for a 67 3/4 ton 4x4
Having trouble with what will fit. It's almost the last thing I need to get inspected and on the road. What years and models will fit. I got one of a 69 2wd 3/4 ton, but no worky. I don't care if it's absolutely correct, I just want to be able to bolt it on. I need brackets and all, so what will fit?
Thanks.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 04-07-2011, 11:58 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Front bumper for a 67 3/4 ton 4x4
Thanks.
Would the one from your '68 panel bolt on?
ETsC10 is offline   Reply With Quote
Old 04-08-2011, 01:08 AM   #3
trapperjack
Looks like, in the dark, that the leaf spring mounts up front will be a problem. Didn't want to rob Peter to pay Paul, but that would be an option if I needed to. Guess I could redneck engineer something for that outside mount, just wanted something easy. easy doesn't always work with these old rigs, though.
Thanks, i guess a few minutes with a socket set will tell me if it will fit.
Old 04-08-2011, 01:43 AM   #4
Livrat
Member #1049
Livrat's Avatar
all front bumpers from 67 through 70 are the same.. the outer front bumper brackets are different between 2WD and 4X4.. you would need outer brackets from 67-70 4X4..
Livrat is offline   Reply With Quote
Old 04-08-2011, 08:52 AM   #5
trapperjack
Thanks Livrat, that's what I was trying to figure out.
