question about instrument panel light
I am putting my instrument panel back in and noticed that one of the instrument panel light bulbs is attached to a gray wire that runs up the steering column. What is that light for and what socket in the instrument panel does it go in? Thanks...
its all about the +6 inches
This is the fiber optic cable that lights up the shift indicator.
It really does not matter where you plug it, but it is supposed to go to the right of the speedo. |
I would assume that the grey wire is the fiber optic wire that sends the light to your shift indicator.
Thanks for the quick replies...another question....is it to the right of the the speedo when you are looking at the back or front of the instrument panel?
Mine will only reach the right as from the front. My fiber optic cable is too short for the other side.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
![]() Join Date: Dec 2002
also, you might want to replace the inst. lamps with #168. These lamps are same physical size as the fact. installed #194. The 168's are 3 C.P. and the 194,s are 2 C.P. ; so the 168 is about 1/3 brighter... If too bright for your desires; just turn down with the lite switch dimmer..........Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
