DON'T TREAD ON ME
![]() Join Date: May 2005
A couple of photos from my "another cheap electric fan build"
For reasons I'll explain shortly, I decided to replace my stock fan set up and, while searching the forum, found the "another cheap electric fan build". After looking at the options I ordered a fan from moparparts.com
![]() ![]() The reason for the switch was due to a pulsing vibration I'd been trying to chase down for several months. I finally determined it was the fan/fan clutch that was causing it. My guess is since these were designed to turn at 4500 RPMs max, spinning them past 6000 RPMs was well past their limits and something has warped. Since electric fans free up HP I decided I had nothing to loose and HP to gain. And so far so good. I rocketed along my county road at 100+MPH and it did just fine on our 90 degree afternoon today.
Old Yeller Last edited by Old Yeller 1970; 04-09-2011 at 10:53 AM. |
dazed and confused
Re: A couple of photos from my "another cheap electric fan build"
Looks good. Need more pictures!
members met: redbaron69, billsbowtie,nc67 |
thanks, never thought of moparparts.com
dealer wanted 350.oo as they'll not sell me the recall replacement without a vin# |
DON'T TREAD ON ME
I should be able to pull it back out today or tomorrow and get a better shot of it.
Old Yeller |
DON'T TREAD ON ME
Signing up for an account couldn't be simpler. You'll need the year model and part # (about half way down the build thread) for moparparts to look it up.
Old Yeller |
all ready saved the part # and the insane 350.00 part # for a jukyard crawl. but 51. new..
ship it |
All I need now is one shroud and two fans for both of my trucks. It is amazining when you think about it, how much stress is put on the water pump with a not very well balanced fan spinning at high speed. This will save parts, HP and labor. Makes everthing under the hood look a lot cleaner also.
That's the same fan I put in. It fits perfectly inside the stock shroud and was cheap and easy.
72 C-10 Longbed (3rd generation truck) 79 K-15 Shortbed SBC400 4in. lift super swampers 05 2500HD Crew 6.0L 39 International P/U (future rat rod) |
#9 | |
DON'T TREAD ON ME
Also, if you need a stock shroud, I still have mine. It's in good shape with only the normal scratches etc from regular use. PM me if you're interested and we'll work out a deal.
Old Yeller |
DON'T TREAD ON ME
Here's a couple of shots with the fan pulled out.
Old Yeller |
Looks very nice! I have been very happy with my mopar fan since I installed it 3 months ago.
I need a new shroud before I do anything
#13 |
I picked up the fan today and ordered the wiring relay kit from Jegs but I dont have a place on the pax head to install the sensor. How do I go about installing it somewhere else? Drilling and tapping the head is not an option for me.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
#14 |
Truck and auto performance nut
if you're turning that many r's....have you upgraded your balancer yet?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#15 |
Disregard, I just realized I was looking at the wrong side of the head. How do I get that plug out of the head?
#16 | |
DON'T TREAD ON ME
Does it use an Allen wrench or is it a square head plug?
Old Yeller |
#17 |
Im not sure yet. I will try to get a better look at it today, someone has filled it with putty or something I have to scrape out first.
#18 |
Its a square head and what I thought was some sort of putty was a broken off square head in there that had been painted over. Got it out. My electric kit will be delivered tomorrow so I will be installing it all tomorrow night.
#19 |
how difficult was it to wire up? where did you tap power from?
1972 C10 Longbed 350/350 |
#20 |
DON'T TREAD ON ME
The wiring isn't difficult. The Jegs kit has everything color coded with an easy to read schematic. The kit supplies a relay so main power for the fan comes from the battery.
On my truck I have a fusible link wire running from the battery to a terminal mounted on my right fender and that's were I hooked up main power to the fan. (I also run my headlights through the same terminal via relays too.) If you have a battery terminal with the two nuts and bolts that tighten down on the starter cable, you could hook it up there. There is another wire that goes to a switched ignition source which I hooked up in my fuse block under the dash. That way the fan cuts off when the truck is off. However, it could be hooked to the battery too, so the temperature sensor will cut it off once the temp drops low enough.
Old Yeller |
#21 |
I am a little confused....is the fan set up 70.00 or 350.00? Did I miss something? How much was the thermostat? And...is there a reason why u guys are using this mopar part? Thanks in advance for any help!
Posted via Mobile Device |
#22 |
DON'T TREAD ON ME
If you buy it through moparparts.com the fan is $70 shipped. If you go to a dealer they may want $350 if you don't have a Jeep VIN. Check out the link in the first post. It explains why the mopar fan.
Here's the Jegs link for the wiring kit. http://www.jegs.com/p/JEGS-Performan...58607/10002/-1 I used the 555-10560 which cost $45.99.
Old Yeller Last edited by Old Yeller 1970; 04-15-2011 at 09:36 AM. |
#23 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I am curious, why would you want to place the temperature sending unit in the head and not the radiator? Your fan cools the water in the radiator, not the engine. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#24 |
I picked up my fan with the supplied part number for 81 bucks. Had it in stock. They used to be cheaper but the originial write up was from 2007. Got my wiring kit from Jegs today and will be installinf it tonight.
#25 |
DON'T TREAD ON ME
Well, Jegs said to put it in the engine (the right head in my case). I think that's logical because that's were the thermostat is and also the sending unit for the water temp gauge on the dash. Since the water heats up there sooner than the radiator, I'd want the radiator fan to turn on and start cooling the water as soon as the engine reached the thermostat's operating temperature. That way cooler water immediately starts to keep the engine cool. Maybe putting the sensor in the radiator would work but I don't see an easy way to mount it.
Old Yeller |
