![]() Join Date: May 2009
Rubber wire loom??
What do you call the piece of rubber, that it’s on the top side of the fire wall, that you can run wiring through? I’ve tried looking in LMC with no luck..it would help if I knew what to search. Or does anybody know where to purchase one? This is a photo of Yezzi’s engine compartment. Thanks in advance.
One shot, one kill.
Re: Rubber wire loom??
This particular piece on this truck is aftermarket or from anoher application, it's not stock to a square. The GM factory one has only 2 screws in it. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot Jim or Paladin whichever you choose.
I would call that a raceway.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case |
I think it came stock like that on the 73 models I found the 67-72 firewall wire harness gutter works just fine. Classic Industries has them. Heres a link
http://www.classicindustries.com/truck/parts/j1012.html
www.squarebodysyndicate.com Instagram #squarebodysyndicate http://squarebodysyndicate.com/builds.html http://67-72chevytrucks.com/vboard/s...d.php?t=496609 http://67-72chevytrucks.com/vboard/s...d.php?t=451831 http://67-72chevytrucks.com/vboard/s...d.php?t=554914 http://67-72chevytrucks.com/vboard/s...d.php?t=506772 |
Thanks Yezzi for the link. Your engine compartment has motivated me to get mine cleaned up. I spent the afternoon working on it, trying to get the wiring fixed and cleaned up, as you know it's a slow process!
| Bookmarks |
