Rear end gears on my 1969 GMC Motorhome??
Have a serious buyer for my motorhome, but, wants to know rear end gear ratio. Wondering if one with wisdom could help me with this?! Here is a link to the post from the 4 sale section:
http://67-72chevytrucks.com/vboard/c...nice-21&cat=12 Thanks in advance for any help you can provide!! Adam |
its all about the +6 inches
Re: Rear end gears on my 1969 GMC Motorhome??
If memory serves, 5.13 is automatic with the DRW option, and also the only one avalible. a 4.56 or 4.10 would be an easy swap but that's as good as it gets without a rear end swap.
Member #1049
Adam, not sure if they are all the same.. but both of my Chinook motorhomes (70 GMC and 72 Chev) had 4:10's and my 72 Weekender (72 chev) has 4:10's
One way to find out is to crawl under and get the code stamped into the top of the rear end pumpkin. |
I used to work on a lot of 1 ton trucks, mostly step vans & they almost all had 4.56 rear gears.
Well it is a 14' motorhome with a 350/auto. Likely as not it has 5.14 gears. I'm not seeing anything on the SPID to indicate the 11K axle (H22 or H23) with 5.43/6.17 gears. Plus it has 16.5" tires.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-11-2011 at 06:54 AM. Reason: wrong picture |
Will it be stamped on the passenger side, on top of the axle tube? Like other trucks..... Thanks to everyone for all the input...and more is welcomed
![]() Adam |
Member #1049
No it is not..
On a H052 it is stamped into the top of the "pumpkin' next to a "rib" towards the drivers side, it is hard to see you more than likely will need a wire brush and some brake kleen and a mirror |
