Picture Request - 6.2 Diesel Cruise Control Mounting
Like to add Cruise Control to my CUCV with 6.2 J code. Need the engine parts/brackets and hardware pictures showing how the servo is mounted to the engine, linkage to the throttle, and the vacuum ball location and plumbing.
I have the majority of the gasoline engine cruise parts but didn't know if there was 6.2 specific mounting brackets and linkage. Will also need to know where the cruise module mounts inside. Any pictures showing mounting and linkage would also be very helpful as I continue to look. Step 1 done (tilt wheel is installed) I have a WTB ad posted as well.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
#2 | |
Next!
Re: Picture Request - 6.2 Diesel Cruise Control Mounting
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
It won't be right if I get A/C either, but that won't stop me from trying...Does your 86K30 have cruise or A/C either one?
I just got back from doing a Security+ class in Savannah GA and there was a 4 door CUCVIII Tahoe on the base...I'd trade even up for my M1009 and my Yukon right now ![]() ![]() ![]()
Next!
I drive the M1028a1 bone stock, no radio, no a/c, no cruise, the 83 K30 dually is bone stock except for an AM radio, my ex US Army C&C ex firetruck now dump is bone stock also. NOTHING whatsoever wrong with creature comfort upgrades though!
My last 2 Civy trucks (89 S10 Yukon and 98 K1500 Yukon) have been loaded and the Burbons and Yukons I was driving in the desert made me pull the trigger on the 03 Z71 Burban in 2004 when I got back...its hard to give that up.
Even the 6 Super Duties and K3500 we have at work now are all A/C and AM/FM radios the Chevy actually a loaded Silverado except no cruise and has a rubber floor mat. Basically all blue GSA trucks the USAF purchased...
Next!
But my REGULAR work truck is the 06 K3500 with A/C, AM/FM CD, 4wd, auto, (toolbox on wheels) and it brings home all the others. Great tow vehicle.
The cruise bracket is diesel specific and bolts to the side of the IP. Don't happen to have a photo but if I get out to the barn I'll get one (got a spare on the shelf). The servo looks to be the same but may have a specific link. Wiring and vacuum run in the LH engine loom. The module goes under the dash, signal switch on stalk, cruise has its own brake switch and bracket. I belive these are common with gassers. You must have a vac pump. Not sure but depending on year the speedometer may need to have the buffer (IIRC that's for 88-up with stepper motor cruise). Do you have the civilian wiring diagram? It's a great help with these.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors Last edited by D13; 04-10-2011 at 11:39 AM. Reason: cause RH and LH aren't the same |
D13,
That would be great and thanks for the info. I do have a 87 and 91 Wiring Diagram manual so between the two can hopfully figure it out once I get the servo bracket and linkage and lay it all out on the bench. If your 87 has cruise would you mind taking a picture of it mounted.
Sure, but it's almost impossible to see the details on the truck (mine's got AC and there's awhole bunch of stiff in a small area).
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
Ahhh A/C...thats the next venture.
PM me your email and I'll ship you pix.
just found this link it is for aftermarket cruise control but it might help http://www.redhummer.com/myhummer/cr...rol/index.html
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
#13 | |
Got some pictures here hope they help.
76 Chevy Crew Cab Build 6.2 Diesel with a Banks Turbo Turbo350c NP205 Dana 44 Front 14 Bolt Posi Rear Quote:
#14 |
Arrived on a Pale Horse
Wish my 6.2 engine was that clean...sheesh.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#15 |
Good pictures...thank you
Is the linkage a piece of tubing and flat stock on the ends to catch the mounting on the IP and servo?
#16 |
He beat me to it! Wow is that clean!
The servo mounts to a stamped bracket that bolts to the side of the UP and has a tab that goes under the IP mounting bolt at the bottom. The servo link is kind of unique plastic part (yellow in the pictures). it goes over a stud on the IP lever. The tab on the bracket with the round hole is where the throttle cable comes in. I've got some off the truck pix that show that a little better. Just lost my email but should be up and running tomorrow.
Tags |
6.2 cruise control |
