How to reach 4x4 engine bay
Hi, folks.
I have a new-to-me 71 Chev K20 with no lift. The engine is in a deep, wide hole. Just touching the carburetor is a challenge, doing good work is even more difficult. Milk crates flop over at the worst times. What's the best way to get in there? What does the well-equipped gearhead stand on? Thank you. |
Re: How to reach 4x4 engine bay
Climb in and sit on the inner fender...
Take out the inner fenders.
Bruce 73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD http://i56.photobucket.com/albums/g1...Rusti192-1.jpg |
Kid's Mechanic
Try this , You might want to copy that and fab your own....Better than a milk crate
http://www.ntxtools.com/network-tool...OTC-1534A.html |
Here is something I'm thinking about gettin. It's a little spendy. http://www.mygaragestore.com/detail.aspx?ID=98
71 Chevy Stepside 377/350 |
I have a foldable step on my 77 bolted to the bumper where the plate goes, the plate bolts to it. It's not good for long term work, but it works well if you just need to reach up and adjust something.
bucket upside down
Rollin in my K5 toaster
If you pull a tire off, you have all the room you need.
#10 | |
Hand Crafted C-10
![]() Join Date: Aug 2006
Do Not forget it's on there before driving away! Also good for racking your shin on. ![]() . Last edited by ETsC10; 04-23-2011 at 12:22 PM. |
I built a 6x2' platform out of some spare lumber. Worked great until one of my legs came off while my dad was helping me and he took the hood latch to the sternum, but that's just due to poor design.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
... let the air out of the front tires
#13 |
What?
Depends.. How old are you, and how much do you weigh?
![]() I myself use to hop right in and sit on the fender wells, and basically straddle the engine. Fast forward 20 years and uh, well lets just say I've put on a few pounds. Now a days, I use those heavy moving blankets and drape them all around the radiator support. Then I have a couple step ladders that I can move from side to side on if I have to, while the whole time being aware of where those steps are. But, really the blankets protect the body work on the truck and yourself from getting dented, scratched, and bruised.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#14 |
78K & 79C Jimmys
i have a couple of wooden boxes 3/4 inch plywood bout 8 inches high to step along
flipped upside down they hold tools/jugs in the truck a buddy built a drive in setup,out of an old deck being replaced ,you drove into a 3 piece deck that you could lift the sides closer and you walked aound the front and sides of the truck and down a couple of stairs @the doors
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#15 |
Hand Crafted C-10
#16 |
Here's how I get to mine.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
#17 |
remove tires and use short jack stands, let air out of tires, step stool.
#18 |
GEARHEAD
This winter when I was doing a lot of engine work, I just pulled the front sheetmetal off the truck. It's really pretty simple and it doesn't take long to bolt it back on.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#19 |
i had plans for a drive up scaffolding type of deal, a board you park on top of and a two foot scaffold around the front of the truck like three walk boards, im short and although i didnt buy a lifted truck i already had plans for a way to work on one if i ever bought one.
#20 |
Post #4 i use that all the time on my mud truck with 36s works perfect
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#21 |
are you guys serious??
#22 |
Currently Blazerless
I use a folding step like in post #4 and also have the topside creeper in post#5, both work well but I probably use my roll around step ladder the most.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#23 |
a big block of wood usely dose nicely!
Car & Truck Projects Google Community. https://plus.google.com/communities/...80679980403145 Youtube channel. http://www.youtube.com/channel/UC2HB...view_as=public 1964 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=419525 |
#24 |
I had the same problem. Just built this out of square tubeing and expanded metal with wheels on one side so it can be moved around easily.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
#25 |
It isn't just 4x4---2wd is difficult too! i just had to add oil last night. The only way i could reach the cap in the valve cover was to climb in----NOT COMFORTABLE for obvious reasons----look at the radiator support as to why.
You really have to be careful about this; i think the topside creeper is a very good tool and cheap insurance against back pain. And trust me, you DO NOT want lower back pain. |
