Old 04-09-2011, 10:21 PM   #1
Inventive1
How to Diagnose a Power Steering problem?
I have a 2002 GMC Yukon. It has the rack and pinion power steering. Today, while my wife was driving it, the power steering quit working. According to her, it happened all at once with no warning.
The belt is on the power steering pump. The pulley on the pump turns when the engine is running. It is full of fluid, with no evidence of any leaks. So I'm assuming the problem must be inside either the power steering pump or the rack and pinion assembly. Is there any way to determine which of these parts needs to be repaired or replaced?
Thanks in advance for any help or suggestions
Inventive1 is offline   Reply With Quote
Old 04-09-2011, 10:44 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: How to Diagnose a Power Steering problem?
I've loosened the pressure line at the R&P and started the engine. If you get pressure, good pump.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
