04-10-2011, 04:04 PM | #1 |
Brake Trouble
On my 71 chevy with a 12 bolt rearend and drum brakes. something came apart and everything inside the drum was chewed to bits. does anyone know where i can find a whole backing plate, and drum assembly along with all the parts inside? I know that i rear disc conversion would be the easiest, but i dont really want to spend that much yet.
04-10-2011, 04:17 PM | #2 |
Re: Brake Trouble
the backer plate adjuster and metal parts you can get from a wrecking yard the springs and shoes from your parts house (Napa might have all internal parts)
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
04-10-2011, 06:39 PM | #3 |
Re: Brake Trouble
We can come up with used parts for it. Call John at 816-584-0563. He has a bunch of salvage vehicles. Call from 9 AM to 6 pm central time.
georgec2434@yahoo.com |
04-10-2011, 08:57 PM | #4 |
its all about the +6 inches
Re: Brake Trouble
backing plate and spreader bar would be used only. Everything else should be avalible at NAPA or a lower quality parts house.
I would recomend trying to locate a vintage drum, the replacement ones suck. |
04-10-2011, 09:26 PM | #5 |
Grandpa in the rustmobile...
Re: Brake Trouble
+2 for actual CHEVROLET USA pieces
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-10-2011, 11:43 PM | #6 |
Re: Brake Trouble
Thank you. i'll probly just end up buying used stuff. I'm just trying to get it on the road so i can drive it till i can afford a conversion kit
04-11-2011, 03:19 AM | #7 |
Re: Brake Trouble
the spring kit for these trucks is usually less then $20 for both wheels. you should be able to rebuild both sides with new hardware and new shoes for under $60 not including wheel slave cylinders not worth getting all used parts, you won't know what shape the used springs are in and if they fail you will have to redo the repair
