04-10-2011, 08:53 PM | #1 |
ashtray removal
just bought a new ashtray, how do you remove the main part that the ashtray slides in? the guides broke off and I now have a new one. It looks like it bolts back in, but not a bolt anywhere to remove it?
Thanks 1972 chevrolet short bed c-10 |
04-10-2011, 09:09 PM | #2 |
Re: ashtray removal
Welcome!
When you take the slide part out, you should see two phillips head screws on the top and two more outside of the slide area at the bottom. You should be able to remove them from underneath.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
04-10-2011, 09:53 PM | #3 |
Re: ashtray removal
If I'm not mistaken, I believe you might have to take off the heater control assembly to get at the bottom of the ashtray...I think that's what I had to do. It insn't too tough and then you can get all the dust off! lol
04-11-2011, 08:23 PM | #4 |
Re: ashtray removal
that is what I thought because all 4 holes are there, it looks like it is welded? could that be? Thanks
04-12-2011, 05:01 PM | #5 |
Re: ashtray removal
It should come out from the bottom...I'd just keep looking, get in different positions. Maybe a pic would help if you can't get it. The P.O. could have modified, although idk why anyone would need to.
11-23-2011, 09:59 AM | #6 |
Re: ashtray removal
Did you ever figure out the removal? I'm in the same boat, my ashtray is welded in also.
10-11-2012, 08:15 PM | #7 |
1972 Chevy Cheyenne Super
Re: ashtray removal
I'd be interested in removal help as well.
-Clayton 1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen |
05-04-2014, 12:01 AM | #8 |
Chance
Re: ashtray removal
I'm on the same boat with my 1972 ashtray assembly as well. I have an assembly I un-bolted from a 1971 parts truck. My 1972 ashtray assembly appears to be welded in too.
Anyone know how I can remove the assembly because it needs to be replaced.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
05-04-2014, 12:47 AM | #9 |
Re: ashtray removal
In my opinion I believe the 1972 ash tray is a better ashtray to use then the 68-71 it comes out a lot farther and is quieter and has more room to get stuff out of the ashtray (I'm not a smoker so I put things in the ashtray that I actually want to grab and get out) and as for taking the ashtray insert out (assuming you already have the tray out) you will need a set if Phillips head screw driver and if you don't want to scratch your heater controls or your dash then I suggest getting masking tape and taping the front and knobs of your heater controls as well as the underneath portion of the dash below the heater controls be sure to remove both Philips head screws before taping the bottom of the dash. Once you've removed the screws (and/or taped your dash) then push the controls as far back towards the firewall as you can and then tilt the heater controls down to make sure the knobs and levers clear the dash then let the controls hang then you can do any cleaning you want under that portion of the dash if not then you can look for the 2 Philips screws pointing toward a the floor for the ash tray dash insert once those are removed you can look at the hole where the ash tray slides into the dash above the tray you will find 2 more Phipps head screws remove those and you can then slide back the ash tray dash insert and pull it out from underneath the dash. And if you do all of these steps in reverse order you can reinstall your new dash insert and your heater controls back in.
