Old 04-11-2011, 01:03 AM   #1
kaine36
need help? on my 67 350 starter just grinds
My 67 350 truck wont start not sher if its the 14'in flywheel or rong starter Any help would be great
kaine36 is offline   Reply With Quote
Old 04-11-2011, 03:00 AM   #2
71gmcburb
71gmcburb's Avatar
Re: need help? on my 67 350 starter just grinds
pull the starter look at the teeth of the flywheel and starter to see if the teeth are in good shape, rotate the engine by hand to insure all is loose there if thats fine take the starter down to your local O'riellys or autozone to have the starter checked to see if all is working properly and cross reference the starter to the books to make sure its the correct unit. if all is right and still grinds then you need to shim the starter for proper contact if it is still grinding then you need a new flywheel
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
14'in flywheel, starter trobleshootig
