04-11-2011, 01:04 AM | #1 |
Gauge hookups
I have a factory gauge cluster in my '65 C-10 and have a question (actually looking for confirmation before I spend the money, LOL).
I am wanting to hook up my factory oil pressure gauge as well as the aftermarket Auto Meter gauge I have using -4 AN braided hoses. I am thinking that I need an 1/8" to -4 AN tee fitting to put in the back of the block ('71 350 block) and then hook up the hoses to the tee fitting and route them to each respective gauge. How far off am I on this one? I am also going to hook up the factory temp gauge as well and realize I need the appropriate temp sender unit for my truck, remove the plug that is in my Performer RPM intake and hook up the wires. I also plan on adding a Volt gauge as well. P.S. Thanks AutoMeter for discontinuing the Sport Comp Silver tach and never introducing a line of gauges that match it. Now I am going to need to buy a new tach as well! |
04-11-2011, 06:37 AM | #2 |
Re: Gauge hookups
Not sure you can get a fitting to go into the back of the factory oil pressure gauge for the #4 you want to run. The gauge is set up for a compression fitting and a 1/8" copper tube. Now you could run the tube from the tee in the block.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-12-2011, 01:37 AM | #3 | |
60-66 Nut
Re: Gauge hookups
You will likely also need a 1/8" to -4 fitting in addition to the 1/8" tee, but yeah that should work
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-12-2011 at 01:38 AM. |
04-12-2011, 05:06 AM | #4 |
Re: Gauge hookups
I was hoping that I could install this in the back of the block (in place of the current copper tubing and ferrel fittings) and then run the an hoses off this to the gauges.
http://www.summitracing.com/parts/FRA-482504/ Am I dreaming that it could be this simple? |
04-12-2011, 06:25 AM | #5 |
Re: Gauge hookups
It will need to set up some to be able to be able to get the lines to clear the block. Another solution would be to run a single #4 line to the aftermarket gauge. On the back of the aftermarket gauge put a tee and off the tee run the 1/8" copper line to the stock one in the dash. Got to go to copper line some time due to the way the stock gauge is made.
Jimmy
04-12-2011, 08:31 AM | #6 |
Re: Gauge hookups
That fitting would work. You might want to use the street elbow type like this http://www.summitracing.com/parts/AER-FBM2031/ and then tee to the (2) gauges under the dash, less clutter under the hood.
I installed a 1/8" pipe nipple and a street elbow on my SBC to get the oil port up to where it was more accessible. Kind of a b i t c h to access down in that recess under the distributor. You could use the one down by the oil filter, but if you are running headers and or a clutch the space down there is just as bad, or worse. Last edited by lakeroadster; 04-12-2011 at 08:37 AM. |
04-12-2011, 09:45 AM | #7 |
Re: Gauge hookups
I bought a little kit from Autometer that was on the rack in my local Pep Boys store. It had a small selection of fittings and some copper tubing. Worked perfect.
04-12-2011, 10:02 AM | #8 |
Artist
Re: Gauge hookups
Autometer also makes the AN kit.... but any racecar shop/summit/jegs. herbert or whoever will have the fitting Captfab is referring to. Thats how I run all mine. I dont mess with the copper lines/or the plastic kit.... over time Ive always had em leak.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
08-04-2011, 03:58 AM | #9 |
Re: Gauge hookups
Update!
I think I solved what I wanted to do. I bought this to install in the back of the block and then run a line to the factory gauge: http://www.speedwaymotors.com/Straig...o-AN4,954.html I may run a "Y" fitting on this to feed the aftermarket gauge as well or just buy a 90* fitting and plumb the aftermarket gauge from the port above the oil filter. This should take care of the issues in hooking up AN lines to the stock gauge: http://www.speedwaymotors.com/Gauge-Fittings,949.html |
