Old 04-11-2011, 10:03 AM   #1
ibad57
ibad57's Avatar
Leaking bag help
I have a right front bag leaking on 72 mounted to plate and cup
i removed line from fill valve and placed valve core fitting to fill bag dipped the core in bucket of water no bubles next day its down
removed bag and all line up to valve submerged it all in bucket added only 25 psi till bag was streched no leaks then reinstalled in truck only to find next day its down again.
What is the best way to locate small leaks the whole setup under water didn't work ????
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 04-11-2011, 12:33 PM   #2
Rollie396
someday it will be done!
Rollie396's Avatar
Re: Leaking bag help
I would suspect the fitting first.Are you installing them with tape?Sometimes the leaks are so small that they are easy to miss.I've had good luck spraying windex on the connections and watch it like a hawk for at least a minute.If it isn't that then it would have to be the bag and that would mean replacing.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 04-11-2011, 03:19 PM   #3
72gmcshorty
72gmcshorty's Avatar
spray soapy water as mentioned
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-11-2011, 04:16 PM   #4
SCOTI
SCOTI's Avatar
When the bags are installed & leaking down, what pressure are you filling them to? Use that same pressure for your testing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-11-2011, 04:35 PM   #5
hotrodhomi
hotrodhomi's Avatar
is it possible that your exhaust valve leaks?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-11-2011, 05:30 PM   #6
ibad57
ibad57's Avatar
as stated put one bag with swivel fitting 3" air line one valve core fitting in submerged tank for 5 min no bubbles but it was a lower pressure didn't want to over strech the bag in water tank? after removing just changed to new line for the corect length and leak is back
is there any dye that could safely show this leak as in aircondisioners??
Old 04-11-2011, 06:11 PM   #7
SCOTI
SCOTI's Avatar
Pressure is pressure. Air the bag up w/more pressure (60-80psi) & see if the leak is present @ the bag. If it's not, start focusing on the lines & fittings after the swivel on the bag.
Diluted dish-water or Windex are the tools I've always seen used to isolate air leaks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-11-2011, 06:17 PM   #8
hotrodhomi
hotrodhomi's Avatar
Snoop, which is soapy water can find small leaks.
'66 impala ht
Old 04-11-2011, 06:25 PM   #9
fixit-p
fixit-p's Avatar
We build allot of oil tanks and trailers with air brakes and all need to be leak tested, the best way I've found is as mentioned already with soapy water but I like to just put a little bit in the spray bottle and shake it up real good to make allot of suds in the spray bottle, so that when you spray it on you'r actually spraying on the suds. The suds will show a small leak allot better than just wet soapy water.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 04-19-2011, 12:49 AM   #10
Rollie396
Rollie396's Avatar
Problem solved?curious minds wanna know.
'80 LWB 2wd beater
my pics
Old 04-19-2011, 07:01 AM   #11
entourageguy
Yellow truck club
entourageguy's Avatar
Better than dish soap is the kids bubble stuff. The new dish soap seams to be loosing it bubble ablility but the kids stuff is made just to make bubbles.....
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 04-19-2011, 10:05 AM   #12
SCOTI
SCOTI's Avatar
This is what I used @ work to find air leaks. They looked @ me funny when I was buying 3 gallons of the stuff....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2011, 12:51 PM   #13
ibad57
ibad57's Avatar
aparently each time i bolt bag with plate back in it must be slight twist on line to cause leak the last install no leaks so thanks for all the sugestions just one of little gremlins to keep agrevating me i hope down the road these leaks don't become a common issue with air ride but i do like the softer ride!
Its holding for now!!!!!!
