Old 04-11-2011, 11:31 AM   #1
62lwbc10
cab mount bushings - poly or rubber?
Hey All, Just wanted to ask about this. I just recieved a set of cab mount bushings for my 62 and I got poly instead of rubber. SOme guys are now telling me the poly bushings are squeaky. ALso they are hard as hell, which surprised me. SO....should I have gotten rubber? Any of you guys use poly and have had any issues?
THanks,
Mark
62lwbc10 is offline   Reply With Quote
Old 04-11-2011, 12:54 PM   #2
creep
Registered Loser
creep's Avatar
Re: cab mount bushings - poly or rubber?
Depends on what you want. Poly will give you less body roll but you may feel bumps more. Rubber will give a softer ride but the body will lean more in turns. I know poly suspension bushings can be squeaky if you don't grease them up good but cab mounts don't move too much and shouldn't be to bad. I have poly on mine but I have a loud, rumbling motor so I wouldn't be able to hear them if they did squeak.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
