Old 04-11-2011, 01:03 PM   #1
JORGIE95961
how do i remove the rear window?
My buddy gave me a sliding rear window and was wondering whats the easiest and most sensible way of removing the window and saving the rubber?
JORGIE95961 is offline   Reply With Quote
Old 04-11-2011, 01:35 PM   #2
m6z
m6z's Avatar
Re: how do i remove the rear window?
I don't think its possible to get the window out and saving the rubber seal. It's not going to be very flexible after 40 years in the sun...
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 04-11-2011, 01:38 PM   #3
JORGIE95961
lol its possible!! and its only been on there about a month..
Old 04-11-2011, 02:18 PM   #4
kcsa75
kcsa75's Avatar
Get a hammer!
Seriously, it shouldn't be a big deal. You should probably have a helper. There may be a locking band on the outside that will need to be removed. It will be either a separate piece of rubber in a groove in the gasket that you can just find the end and pull out or there will be a ridge where one piece of the rubber overlaps the other. If it's the latter, find something that you can put between the two sides -- a cotter pin puller works best, but a screwdriver will work -- and go around the whole window, then you should be able to CAREFULLY push the window out. Get it started in a corner and CAREFULLY work your way around the glass. Once you get about half-way around it should come right out.
If you don't have either, from the inside just start working the rubber gasket loose while gently tapping the glass out. You should probably have your helper stationed in the bed to catch the glass once it's loose.
To put the slider in, wrap the rubber gasket around the sliding window, then get a piece of string and place it in the grove where the gasket goes over the flange on the cab. The string should go all the say around and both ends should meet in the middle on the bottom. Have somebody hold the glass up to the opening with the strings inside the cab. Then start working the gasket over the flange by pulling the string out while your helper on the outside GENTLY taps the outside of the glass. Once you get it started, it actually goes pretty fast and easy. If it's stubborn you may want to use some liquid dishsoap on the gasket, but I wouldn't use soap unless I have to as it can get to be a mess.
Good luck!
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-11-2011, 02:22 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
If you only want to save the rubber and not the glass, a hammer works pretty good.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 04-11-2011, 02:25 PM   #6
JORGIE95961
lol thought about it
Old 04-11-2011, 03:43 PM   #7
heeroyue2002
fat old dude
heeroyue2002's Avatar
i used a long flathead and one of the plastic sticks used for taking the tire off a bike rim. hit it was soap wedged the screwdriver in carefully and then slid the plasic until a good amount was free and then it pulled out.
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 04-11-2011, 05:06 PM   #8
m6z
m6z's Avatar
well you didn't say that it was only a month old..... Shouldn't be to bad with a gasket that's still new.
Doug
Old 04-11-2011, 05:20 PM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
Go get a small garden hose, from inside the cab, pull the rubber flange down (on the gasket), and insert the hose there, and then continue to move around the window pulling down the flange and using the hose to hold the flange out. Then once you have 1/2 - 3/4 of the gasket pulled back with the hose, you will be able to gently push out the window and gasket together.
(edited, I meant 1/2 to 3/4, not 1/4. )
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-11-2011, 05:22 PM   #10
JORGIE95961
Originally Posted by john fabris View Post
go get a small garden hose, from inside the cab, pull the rubber flange down (on the gasket), and insert the hose there, and then continue to move around the window pulling down the flange and using the hose to hold the flange out. Then once you have 1/2 - 1/4 of the gasket pulled back with the hose, you will be able to gently push out the window and gasket together.
wow. I doi recwll seing this done.. I think tey used a smal extension cord as well.. Cool thanks
Old 04-11-2011, 05:59 PM   #11
John Fabris
TOTY 2006
yup, an extension cord would work as well.
John Fabris
67 C10 SWB
