Toyota wheels
More questions on wheels. I have heard that our trucks have a hub bore of 3.5 inches (88.9mm). I see some good looking toyota wheels with the hub bore of 108mm. Also our trucks have the 6 on 5.5, does this translate to the 6 on 139.7 that the toyotas have. If so, will these wheels work on our trucks? and if so, has anyone used them. If so, would like to see what they look like.
Re: Toyota wheels
I used a Toyota 4Runner spare on my 6 lug '69 when I got a flat. I know the Toyota 6 lug is the same as Chevy, but not sure about the hub bore.
<edit> I know a lot of people have put 18" steel wheels off the new FJ on as well without modifying anything.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 04-11-2011 at 03:48 PM. |
UCA63
Re: Toyota wheels
Yes 5.5 inches = 139.7 mm
T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Toyota wheels
What about the bore?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Re: Toyota wheels
If you're talking about the steel Toyota wheels, the offset if wrong.
I assume the nicer ones are too. These were the rollers on my 63 when I bought it.
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
