Old 04-11-2011, 06:25 PM   #1
peglegs
peglegs's Avatar
timing & carb. id please
The only #'s i can find on the carb. are 2241 9635SA on the fr. rt. bolt flange no names anywhere
#1 Would you know what carb. this is in the picture.
#2 How many turns on the air/fuel adj. i have it at 1 1/2now
#3 What timing would i start with for a 327, HEI dist with a RV2 cam
B-4 i adj. the air/fuel mix from about 3 1/2 turns down to 1 1/2 turns out the engine wouldnt stay running w/o giving it more gas & was surging while going down the road.
At this point the only bad symptom is diesling once out of the last 3 times i turned it off but running pretty smooth.
again thanks to all for the help
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 04-11-2011, 06:34 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: timing & carb. id please
That's an Edelbrock/Carter carb.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-11-2011, 07:00 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Pardon my ignorance... but what is an RV2 cam?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-11-2011, 07:09 PM   #4
QKENUF4U
QKENUF4U's Avatar
take air/fuel screws in till starts to stumble and bring back out 1 turn is how ive always set my CARTER AFBs (now edelbrocks)
the cam card should have a timing spec on it (look it up on manuf. website if you dont have it)
3 1/2 turns out was WAY WAY RICH thats why you needed more throttle (air)
some info about your run-on problem.... http://en.wikipedia.org/wiki/Dieseling
QKENUF4U is offline   Reply With Quote
Old 04-11-2011, 07:10 PM   #5
QKENUF4U
QKENUF4U's Avatar
Gary
http://www.22re.com/main/toy/rv2.htm
Old 04-11-2011, 09:08 PM   #6
GASoline71
GASoline71's Avatar
So it's a grind for an I-4 used in a V-8 grind.
Gary
Old 04-11-2011, 09:59 PM   #7
peglegs
peglegs's Avatar
Gasoline, when i had the long block built i asked what was a better than stock cam for towing a small camper the RV2 cam was better for taking off and low end towing
Old 04-11-2011, 10:02 PM   #8
GASoline71
GASoline71's Avatar
Cool beans... I've just never heard of one before.
Heard of "RV" cams... but not an RV2 specific.
Gary
