Old 04-12-2011, 09:56 AM   #1
JORGIE95961
Th350 tranny kickdown cable
Ok so im almost done iwth my manual to auto swap.. but im stuck here.. my kickdown is about two inches short...???? i also swapped out motor intake and car from a dinky two barel to the 4bbl.. i used the bracket that was on the 2bbl intake whick i thought was the same on them all..... actually my throttle likake wont fit on its bracket either... on the thgrottle the origional truck with this engine . never had a throttle bracket... any ideas on thios stuff? do i just make an extention..?
JORGIE95961 is offline   Reply With Quote
Old 04-12-2011, 12:50 PM   #2
mrein3
mrein3's Avatar
Re: Th350 tranny kickdown cable
On my truck (small block V8, Edelbrock 4bbl, th350, 4wd) I'm using the TV cable the Chevrolet factory worker put on my 1971 Monte Carlo (small block V8, 2bbl).
I believe all the cables are the same. You just need the correct bracket that the near carb end of the cable clips in to.
On my truck I purchased an aftermarket Edelbrock piece.
Just this past weekend I re-confirmed the "kick down cable" still works. My poor truck spends its winters in 1st and 2nd gear plowing my driveway and driving out to the fish house. After pulling the plow Satruday I took it out on the paved county roads and dropped the hammer on the 383. Man that hurts when you bounce your head off the back window.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
