Old 04-12-2011, 01:19 PM   #1
manimal
manimal's Avatar
Alternator swap...not GM
I will probably get crap for this, but I have done SEVERAL of these alternator swaps and am VERY impressed.
I am using a Ford 3G alternator from a mid 90's Taurus.It's called a 3g. It puts out 95a @ idle! It's rated for 130a max. The wiring is very easy. It's internally cooled and internally regulated. I am also installing a ford starter solenoid. Here are some pics and diagrams.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-12-2011, 02:39 PM   #2
tucsonjwt
Re: Alternator swap...not GM
I went with a 140 amp GM alternator from a place called (Quick Start, I think) and also had a Ford solenoid setup installed. I was trying to overcome the "heat soak" hard start when hot condition in my 83 C20 big block. Seems to have helped.
tucsonjwt is offline   Reply With Quote
Old 04-12-2011, 02:49 PM   #3
Pop's C-10
Pop's C-10's Avatar
No crap from me..it's always good to have options...more pics & info
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-14-2011, 10:03 AM   #4
manimal
manimal's Avatar
Wow, I thought this would get more attention. I guess I will have to do a write up.
-Lance
Old 04-14-2011, 09:20 PM   #5
hatzie
Moderator
hatzie's Avatar
Crossbreeding electrical systems can work when you're limited to parts on hand. I used a Hitiachi from a wrecked `84 Subaru on my 1981 Rabbit Diesel.
The Delco AD230 and AD244 from the 90s GM trucks are another good option to boost your amps.
