Old 04-12-2011, 01:52 PM   #1
britski
Angry Need Help....72 C10 Keeps Dying
I have a 1972 Chevy C10, 350 2wd.
Recently it starts up fine but when I get around 2 miles down the road it will die. After trying to start it a couple it times it will barely turn over almost like the battery is dead but it hasn't been turned over enough to drain the battery. After I leave it for 45 minutes to 1 hour it will start back up no problem. It has done this three times and it dies at about the exact same distance from my house each time.
When it dies it immediately does so. No sputtering or misfiring. Just stops. I recently replaced the coild wire thinking that may be it but it didn'thelp.
I have a few ideas of what it may be but I need opinions before I just start blindly replacing stuff.
britski is offline   Reply With Quote
Old 04-12-2011, 03:00 PM   #2
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Re: Need Help....72 C10 Keeps Dying
What does it do after you wait and start it up again, does it die again, or keep going?
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 04-12-2011, 03:01 PM   #3
Impalapawpaw
Impalapawpaw's Avatar
Originally Posted by britski View Post
i have a 1972 chevy c10, 350 2wd.
Recently it starts up fine but when i get around 2 miles down the road it will die. After trying to start it a couple it times it will barely turn over almost like the battery is dead but it hasn't been turned over enough to drain the battery. After i leave it for 45 minutes to 1 hour it will start back up no problem. It has done this three times and it dies at about the exact same distance from my house each time.
I have a few ideas of what it may be but i need opinions before i just start blindly replacing stuff.
mine is doing the same thing and i have 2 batterys.i also loose gas in the bowl. Crazy i have tried mine diffrent things.if you find out something please post on here and i will do the same
Impalapawpaw is offline   Reply With Quote
Old 04-12-2011, 03:21 PM   #4
britski
It will eventually die again. Everytime I have managed to start it again I just take it straight home so I don't go far with it.
One of the theories that keeps coming up is the ignition coil is over heating. This would explain why it is starting after it sits. Anyone know if this is true???
Old 04-12-2011, 06:00 PM   #5
AirSpeed
AirSpeed's Avatar
My 69 C10 used to do that, it turned out the float had a hole in it. I tried to buy a new float but no one had one, it had a Rochester "two jet" carb. The float had actually broken apart at the seam, I took it out an soldered it back together and havent had any problems again.
It was a pain soldering the float, every time I would get it almost sealed the heat would blow out the last bit of solder, I finally submerged the lower part in water and soldered the last bit closed.
AirSpeed is offline   Reply With Quote
Old 04-12-2011, 07:22 PM   #6
68gmsee
Active Member
68gmsee's Avatar
First make absolutely sure you have good cables and connections to the starter and ground. The cable posts can get corroded internally and is not visible unless you peel back the sheathing.
Second, buy or borrow a volt meter and place it across the battery posts and with the engine idling insure you are getting at least 13 vdc or more it may read betseen 12-14.5vdc depending on battery charge.
68gmsee is offline   Reply With Quote
Old 04-12-2011, 07:58 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
HEI or points?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-12-2011, 09:30 PM   #8
72lb4x4
I'd guess a loose wire in the ignition circuit...
72lb4x4 is offline   Reply With Quote
Old 04-13-2011, 01:39 AM   #9
britski
It has points
Old 04-13-2011, 07:01 AM   #10
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Id start with a coil ( or maybe relocate yours to keep it cool) a condencer...I think your on the right track...another dumb thing loosen the gas cap and see if the vent is toast
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-13-2011, 08:18 AM   #11
cdowns
cdowns's Avatar
i'd start by removing battery cables and clean up all 4ends and where they mount next i'd clean and gap the points and plugs then i'd replace the gas filter (if quadrajet) it is inside the carb body i'd also blow out the air filter while i'm at it
Old 04-13-2011, 01:25 PM   #12
GASoline71
GASoline71's Avatar
Check the condenser in the points ignition sysytem.
Gary
Old 04-27-2011, 04:05 AM   #13
britski
Well I figured I would update for anyone that runs in to this same problem. Turns out the problem was in the distributor. It would just quit working for no real reason and at times the coil would quit. The coil issues was most likely the negative post going out from the distributor going out.
Needless to say, everything I researched said that the points are very unreliable so it has been converted to an HEI set up now.
Old 04-27-2011, 09:59 AM   #14
68gmsee
Active Member
68gmsee's Avatar
Glad you found the problem. I had the same thing happen to me on my 69 with an HEI dis so I should have considered the distributor/coil as a possibility. What threw me off is when you mentioned the engine barely turning like the battery low on voltage.
Thanks for update.
Old 04-27-2011, 10:04 AM   #15
Hottrucks
Hottrucks's Avatar
Did you swap the hole Dizzy?? if you did remember that the voltage from the yellow wire isn't a full 12V so you need to run a new wire....
as far as being unreliable?? well they have been run for a loooooooooong time..I have no choice except an update for my Caddy and it runs fine..
Glad you got it fixed reguardless
Old 04-27-2011, 01:54 PM   #16
britski
Yeah the whole thing has been swapped. I guess unreliable isn't the word to use. KNown for causing some headaches and alot more maintenance is what I should be saying.
