Old 04-12-2011, 02:21 PM   #1
willstruck
coolant leak
I have a coolant leak, from the waterpump area. it almost looks like it's the timing cover though. is this possible?
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
Old 04-12-2011, 02:45 PM   #2
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
Re: coolant leak
It is not possible for water to come out from the timing cover, but it could be coming from where the water pump bolts up to the block. Check it again, could be the gasket leaking.
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 04-12-2011, 02:54 PM   #3
Pop's C-10
Pop's C-10's Avatar
Re: coolant leak
It's tha weep hole or tha bolt..if it's coming from tha weep hole in tha pump..them tha pump is toast..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-12-2011, 07:36 PM   #4
willstruck
Re: coolant leak
Thanks. I read the same online, went ahead and replaced the gaskets. Seems to be fine now.
