Old 04-12-2011, 02:45 PM   #1
lwb66step
lwb66step's Avatar
Rear End Options and Lowering
Hey everyone, I have a 1966 LWB stepside that I would like to fit with a more modern suspension / braking set up. I def want to go disk brakes up front and would like to convert to a 5x5 lug pattern. my issue is with the rear end. What do I need to do to convert my rear end to a 5x5 setup? What are some donor rear ends that I should be looking for? What types of vehicles should I be searching my junk yard for? Any advice you can give me would be appreciated. I also want to slam this truck, mostly because I don't see anyone on here with a slammed / bagged LWB step side. Thanks in advance for the replies!
lwb66step is offline   Reply With Quote
Old 04-12-2011, 03:08 PM   #2
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: Rear End Options and Lowering
I am looking at doing the same thing. From what I have been told (and plan to do) you can swap the rear end from any other trailing arm style truck that has the 5 lug. Then, I plan to swap to a later crossmember, which gives you disc brakes and the 5 lug.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 04-12-2011, 03:48 PM   #3
jimmydean
jimmydean's Avatar
My plan is to use an Impala SS rear since it is 5x5 to match my disc front and that gives me discs all around plus the lower gears and posi from the SS.
An easier swap would be a 71-2 trailing arm rear axle. There is a guy here in town that sells "disc swaps" that are the front cross member and matching rear axle from a 5 lug trailing arm truck. He wants WAY too much for them, but it's a bolt in swap.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-12-2011, 06:01 PM   #4
creep
Registered Loser
creep's Avatar
You can also get replacement axle shafts that convert to a 5X5" pattern. Or you can have your originals redrilled. I put a Chevelle rear in mine and had them redrilled for about $150.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-12-2011, 09:30 PM   #5
scrapmetalart
Junior Member
re drill the axles
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 04-14-2011, 11:48 AM   #6
lwb66step
lwb66step's Avatar
thats what i think i am going to do. just keep the original in there and redrill the drums. does anyone have a suggestion on getting rid of the giant hub ring protruding from the rear drum? I cant find any rims with a center bore large enough to fit around it.
