Do many of you run your tranny cooling system independent of your radiator?
I have talked a little about this before but I lost a tranny to a bad radiator once and would just like to know how many of you do this. I can either run it seperate or buy a new radiator and hope for the best since that doesn't seem to happen to often but still, who runs them seperate? Thx in advance.
Re: Do many of you run your tranny cooling system independent of your radiator?
ive always heard to piggy back them.run the line coming straight outta the trans into the radiator then from radiator into the cooler then back to the trans? thats what i plan on running with my truck.
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
Active Member
![]() Join Date: May 2005
Since you live up in the cold part of the US, you need to run it to the radiator. Cold fluid is just as bad as fluid that is too hot.
So run it to the radiator, and then to an external cooler (if you tow/haul a lot) and then back to the trans. Or just the stock setup if you're not towing etc, will be just fine. Jason
Cadillac Powered |
i ran mine in conjunction with the rad and it does great and i have a very small diameter stall converter so the fluid does not stay in there long so it needs to be cool
Got it and thanks guys.
Living in hot as heck florida I always run a separate cooler and it has worked great in all my buckets.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
![]() Join Date: Mar 2011
I run a separate cooler to the trans on my 50 pickup. Have also installed separate cooler on the last 3 cars I worked on, everything works fine.
not 100%, but fairly sure its B&M
I prefer to change the tranny rather than cool it.
![]() Posted via Mobile Device
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
