Old 04-12-2011, 11:22 PM   #1
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Polyurethane Control Arm Busings... better or worse than OE type
Ive been wanting to rebuild the control arms... havent bought anything, but I was going to get MOOG brand stuff because its name brand and supposedly good quality. It would be like 140 ish to do all of the control arms... but Summitracing has an Engergy Suspension front control arm kit w/shells for 60 bucks:
http://www.summitracing.com/parts/ENS-3-3161G/?rtype=10
I know a lot of people here have used something like it, but I dont know anyone who has...
Do you like them?
Could you tell a difference? or just needed to be replaced?
Have you had to replace them due to worn out..if so how long did they last?
Basically I dont want to buy something thats not going to last... ive read they are a pain to do, but Ive got the prep covered.
thanks fellas,
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-12-2011, 11:32 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Polyurethane Control Arm Busings... better or worse than OE type
Clint, here's what I know. Unless I were building a chassis strictly for performance, I would not use polyurethane. It is very firm, and is known to cause harshness due to its inability to deflect. To compound all of this, it is inherently prone to squeak. I know they make grease specifically to prevent the polyurethane squeak, but its a bandaid at best.
What I have used and was very pleased with are poly-graphite bushings. The graphite impregnated compound of poly-graphite gives you most of the firmness of polyurethane, but minimizes the harshness. Because it is self lubricating, the bushing deflect more readily, and have do not squeak.
If it were me, I would check the forum vendors to see who can supply you with a poly-graphite rebuild kit. I think you will be very pleased.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-12-2011, 11:44 PM   #3
54Caddy
GM Addicted
54Caddy's Avatar
I have poly on my truck. I like the way it feels. Have poly cab mounts, radiator support mounts, control arm bushings, sway bar bushings, tie rod end dust boots, motor mount, trans mount, and rear leaf spring and shackle bushigs. Real nice man have no complaints have put about 25,000 miles on them on bumpy rought roads and no problems at all. Oh yea and all my shocks have poly also
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 04-13-2011, 01:24 AM   #4
bluex
bluex's Avatar
If you get the black bushings from energy suspension, they are ploy-graphite as well. The red ones are just poly and will eventually squeak....
Also check amazon, thats where I got my control arm set. If I remember right it was less than $40....
bluex is offline   Reply With Quote
Old 04-13-2011, 11:58 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Last truck I built I went with Energy Suspension poly bushings from Summit because they were a lot cheaper than Moog rubber stuff.
They squeaked. I even bought the super giganto sized tub-o-lube from Energy Suspension and slathered it on like cake icing. Still squeak.
Never again.
Old 04-13-2011, 07:33 PM   #6
87chevy.com
yeah they are definatly cheaper than moog, but my 87 is squeek and rattle free.. i dont want to bring an annoyingn squeeak into the mix.... i like the solitude. guess i'll do the moog.
clint
Old 04-13-2011, 07:38 PM   #7
87chevy.com
ha, found the video that just killed the though tof putting the energy suspension bushings on my truck..
eww.
clint
Old 04-13-2011, 08:05 PM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
everything I ever had them on.... squeek squeek squeek
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-13-2011, 08:59 PM   #9
Pop's C-10
Pop's C-10's Avatar
YouTube - Squeaking poly bushings
eww.
clint
That's tha way my camaro sounds..lol
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-14-2011, 12:09 AM   #10
54Caddy
GM Addicted
54Caddy's Avatar
i dont understand why mine dont squeak then. Mine are energy suspension and not one issue at all
..Mac’s Garage..
IG:MacsGarage
Old 04-14-2011, 08:14 AM   #11
stich626
I wish global west would make their delalum alum bushings for these trucks
you have to keep them greased but man.. it helps make cars run on rails
stich626 is offline   Reply With Quote
