Old 04-13-2011, 12:12 AM   #1
aztim1968
manual transmission to automatic conversion
I was wondering if there were any threads or pictures on the conversion of a three speed manual to an automatic transmission. I need all the help I could get. Thx
aztim1968 is offline   Reply With Quote
Old 04-13-2011, 12:29 AM   #2
dan42
dan42's Avatar
Re: manual transmission to automatic conversion
Lots - Do a lookup on the top right. I'm gonna move this thread so you get a little more traffic -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-13-2011, 01:00 AM   #3
aztim1968
Thanks, new to the site.
Old 04-13-2011, 03:40 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
It's fairly simple. You will need an automatic trans cross member, auto linkage, auto column, flexplate, and possibly a starter. The hardest part for me was removing all the rivets that attach the manual trans cross member to the frame. I used an air chisel, but it was very noisy, even with ear protection. If you can find a truck with the auto setup in it, take all the pieces and it will be an easy swap. I have an inline six and I had to experiment with starters until I found the right one. I finally ended up using a starter for a 1970 350 engine. The only other problem I ran into was the linkage rod that runs from the frame bracket to the steering column was not long enough, but my setup came out of a truck with a V8. Good luck and welcome to the board.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-13-2011, 04:13 PM   #5
JORGIE95961
i just finishe ddoing this:
tranny
torque converter
flywheel, dont forget to take out the piloy bearing
tranny cooler or radiator that has option
cooler lines
vacuum lines.
auto tranny crosmember
detent cable and bracket
yoke for your new tranny,
shortened driveshaft
shift linkageand coulumn, or some sort of kit
back up light wiring
JORGIE95961 is offline   Reply With Quote
Old 04-13-2011, 11:34 PM   #6
aztim1968
Thanks everybody I am in the process of finding everything I need to complete the conversion. I will post pics as I proceed. If anybody knows where I can also get a power steering pump and gearbox in Phx please let me know, Thanks again everybody.
