Old 04-13-2011, 09:22 AM   #1
JORGIE95961
dISTRUBUTERS HAVE ALWAYS BAFFLED ME
To th epoint where thats the only thing left on my truck after i tore it down... Lastnight i went to but my cap on my dizzy to try and start truck.. set thge engine at tdc, timing mark at 0. but rotor not pointing to no 1 cylinder on the head. did it three times and the only time the no 1 piston was at th every top and my timing marks where at 0 the rotor pointed toward the driverside firewall.... The truck ran fine whern i bought it and it made the 50 mile trek home no problem... I got it to start and run exactly where everything origionally was from the. How in th e world is my rotor supposed to point towards my no 1 cylinder.. i always though the distrubutor only went in two ways.. im so confused... then my buy told me the only reason i can only get it to go in two ways is because of the oil pump.. wow that got me even worse!!!
JORGIE95961 is offline   Reply With Quote
Old 04-13-2011, 09:56 AM   #2
don t. - 72gmc
Re: dISTRUBUTERS HAVE ALWAYS BAFFLED ME
In a nutshell....
...find compression stroke TDC of cyl #1.
...insert dizzy and rotor. End of dizzy has a slot to connect w/the oil pump.
...where rotor is pointing to on the cap is #1.
It makes no difference if the rotor is pointing front, back or sideways, that is #1.
...install cap, add remaining plugs. If the engine is a sbc/bbc, firing order is 1 8 4 3 6 5 7 2
HTH..good luck...don t. ....
don t. - 72gmc is offline   Reply With Quote
Old 04-13-2011, 09:57 AM   #3
JORGIE95961
Originally Posted by don t. - 72gmc View Post
in a nutshell....
...find compression stroke tdc of cyl #1.
hth..good luck...don t. ....
thanks got it and done
Old 04-13-2011, 09:59 AM   #4
cdowns
cdowns's Avatar
maybe start with a good service manual// verify TDC by using a piston stop to verify timing marks and location then stab distributor for proper location
Old 04-13-2011, 09:59 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
It's explained real nice in the back with pictures of the "How to rebuild your small block Chevy" book. I always turn to that when I have to refresh my memory.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-13-2011, 10:11 AM   #6
JORGIE95961
i GOT THE BOOKS FELLAS.. BUT THERES no substitute for what i just learned from Don t.
Old 04-13-2011, 10:13 AM   #7
leddzepp
Moderator
leddzepp's Avatar
In a nutshell....
x 2. Simplest way to do it
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
