Old 04-13-2011, 07:29 PM   #1
chevyk10boy
chevyk10boy's Avatar
i accomplish and steering column change
i bought a 88 column and got it to fit my 85 chevy k10..
cheverolet good lasting truck and good looks
chevyk10boy is offline   Reply With Quote
Old 04-13-2011, 09:21 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: i accomplish and steering column change
Cool!
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-20-2011, 09:39 PM   #3
calvinmitcheal@yahoo
What did you have to do? I am 6'4" and my stock non-tilt steering wheel in my 1987 chevy truck just doesn't work. Looking to upgrade
calvinmitcheal@yahoo is offline   Reply With Quote
Old 04-20-2011, 09:40 PM   #4
lilpoindexter
lilpoindexter's Avatar
Now all we need is a ton of pics...
lilpoindexter is offline   Reply With Quote
Old 04-25-2011, 12:44 AM   #5
chevyk10boy
ill get pics up tommorw hopefully..i just have to finsih wetsanding and buffing my truck first.
Old 04-25-2011, 02:03 AM   #6
Pop's C-10
Pop's C-10's Avatar
I'm 6'2'' & with a bench tha wheel i to close for my liking..i was think about sliding tha column up like tha 67-72 guys do there..adding a smaller wheel may help, but like tha stock 2 spoke
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-25-2011, 11:27 PM   #7
KC_Goose
I have a 75' with bench seat and non tilt and been thinking about changing to tilt..is it remove and replace or do you have to mod anything..
KC_Goose is offline   Reply With Quote
Old 04-25-2011, 11:57 PM   #8
Mr. 250r
Mr. 250r's Avatar
I put a 91 tilt in for my non tilt 91 if that makes sense but for mine it was i think 5 small bolts on the inside firewall, plus the two holding it two the dash, all the plugins, two on the outside of the firewall, the actual steering shaft has a plastic pin in it and for mine i had to use the tilt steering steering shaft because the non tilt was different. Then again not sure how they changed throughout the years i also put i think an 88 suburban column in 85 silverado
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 04-26-2011, 12:41 AM   #9
BIG V
its remove and replace
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 04-26-2011, 09:40 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
curious i'm gona be doing 88 or 89 to 78
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-26-2011, 09:46 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
As long as you get the same year column. Over the years there have been several changes to the harness and connectors. They moved the wipers from the dash to the column as well. It can be plug and play, but not always.
Articles-
"Refining Sierra"
Old 04-27-2011, 12:49 AM   #12
Mr. 250r
Mr. 250r's Avatar
here is some pics of an 91 suburban column i also put an 88 in an 85 so i know those will work not sure how far the changes go back but there's two nuts holding it to dash *The ones pointing straight down not at an angle*, but first you must remove lower part of column, metal piece and air duct, next go to the 5 bolts on the inner firewall, two nuts on the outside firewall, shift linkage, 2 plastic inserts shaft. Drop column down and remove wiring which is 2 big plugins, a long skinny one, neutral safety switch, possibly a few more its been awhile but its really easy
2003 1500 Silverado
