Old 04-13-2011, 08:09 PM   #1
dzbowtie
dzbowtie's Avatar
70 c10 door locks?
i replaced the lock cylinder in the driver door and am having trouble getting it to lock. i can lock it from the inside and when i close the door it unlocks. then when i try to use the key to lock it, it still will not lock. any ideas? the knob only seems to go down half the normal distance also when i push it down if this helps
dzbowtie is offline   Reply With Quote
Old 04-14-2011, 09:58 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 70 c10 door locks?
I have the same trouble....i actually lift up on the door handle (lightly....remember that door handle is pot metal) while turning the key....also, I believe as a safety precaution the door unlocks when you lock it and close the door just in case you left your keys in there...thus the reason you have to lock with the key
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-14-2011, 09:03 PM   #3
dzbowtie
dzbowtie's Avatar
thanks for the tip, after adjusting the latch etc several times, finally i did what you said. i leaned in on the door a tad and was able to lock it with the key. suppose the door is off just a hair
Old 10-01-2012, 10:00 PM   #4
Square_78
Square_78's Avatar
Mine is doing the same thing but its something inside the lock itself that not allowing the key to turn without a lot of messing around. Sometimes takes a few minutes of wiggling to get the key to turn. I guess my lock is just worn out.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 10-02-2012, 03:59 PM   #5
dmw319
my solution: truck is always unlocked. haha
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 10-02-2012, 07:53 PM   #6
Tinsmith9
dmw, Same solution works great for me too!
Dan
Tinsmith9 is offline   Reply With Quote
Old 10-03-2012, 12:13 AM   #7
Kidd-7
Kidd-7's Avatar
If the cylinder is the issue, try some grafite lub like LockEz. I had some bodywork done on my wife's car and neither lock would rotate, squirted some LockEz in there moved the key around, no problems since. Just watch the drip if you have nice paint.
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
