Suburban wheel options
When the time comes and I finally lift the Suburban (3/4 ton) I figure I will change out the wheels as well. Maybe something a little wider to accommodate a larger tire and somewhat make up for the difference in axle width. I was just wondering what you guys are running or what you have seen run that looks good. Pictures are appreciated, thanks.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
Re: Suburban wheel options
I like the looks of Mickey Thompson Classics on these trucks.
Here is a pic with 33"x12.5/16.5 on a stock suspension.
1987 R10 Chev Suburban 6.2L Diesel 1984 Frame 1990 Body V20 Chev Suburban 6.2L Diesel Banks Turbo |
^^^^^^^^^^^^^^^love those^^^^^^^^^^^^^^^^^^^^^
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
Here is a pic of mine with 35's on Weld 16.5 8 lug rims and a 6 inch lift....ok technically 4 inch lift but actually 6. I ripped out the old 1/2 ton springs and put in 1 ton springs.
![]() Last edited by iluvmy72; 04-16-2011 at 02:27 AM. |
#5 | |
To even out the axle width, I just installed wheel spacers on the rear of mine. That way the Backspace on all of my wheels are the same, not making any difference which corner the are installed on. To each his own though. Some people will say that spacers are dangerous, others will tell you they have been running them for years w/o issue. 2.5" spacers put the rear wheel track a bit wider than the front. The look I wanted. Turn radius was decreased a bit, but these things ain't made for cornering anyway.
When I get ready for a new set of wheels, they will get a minimal backspace too. To hang the tires out a bit farther. W/o the rear spacers; ![]() ![]() With spacers; ![]() ![]() With the flares installed; ![]()
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
Wheel spacers should never, ever be used for looks!!!! They are dangerous and most states now are outlawing them. Cops are pulling people over to give a "fix-it" ticket to have them removed from vehicles.
#8 | |
Wheel Spacers are used a lot. Adapters are used too. How much Stud is exposed thru the nut or are only a few threads of the nut holding the wheel on? By the way I do not have spacers on my Suburban. But If I ever did,I would not question doing it. As long as I did it properly. |
#9 | |
As I stated on my original post, the opinions on running spacers are pretty much polarized. Either someone has no trouble at all with them, or someone has had one break and would never run them again. Both very understandable opinions/exeriences to me. If I have one fail in any way, I will certainly take them off and never run them again. But I guess I will just keep my fingers crossed and hope I'm one of those fellas that doesn't have any issues with them, which goes against my trend of luck.
I should clarify. I bought and installed the adapter style spacers. I have plenty of stud through the lug nut holding them on, and I will watch them very carefully to hopefully catch any problem before a wheel passes me on the road. I had the same dilemma about the rear spacing. I wanted to cut the fenders instead of lifting the burb more so it would clear my tires. I didn't want to trimmed fender look, my preference, so i bought the fender flares. I knew it would look plain stupid to have the front fenders flares filled out with the tires, and the rears still be tucked up under the body. So I either had to run less backspace on the rear wheels, or space them out. I chose to space them out so I wouldn't have to have a dedicated front and rear backspaced wheel. Again, my preference. As for the fender flares, I got them from 4wheelonline. They had about the best prices I could find, and have a dist. center close to my house, so I could willcall them.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() Last edited by Psycho71; 04-26-2011 at 10:59 PM. |
78K & 79C Jimmys
are they bushwackers?
any fit issues? they look good no wheel extenders/adapters for me pls
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 04-26-2011 at 09:40 PM. |
yes, bushwackers. They are the cutout flares, so no fitment issues if you use the saws-all correctly
#13 |
38.5s on some size wheel ill have to get tomorrow and 4in suspension with 3in body no rubbing except when i ramped a hill and smashed the bottom of the fender up a bit
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#14 | |
78K & 79C Jimmys
and yup i can use one correct,i practiced cutting the roof off my car lol
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#15 |
Ridin' Dirty
Not a Burb, but same diff. (no pun intended) I'm using Hummer H2 17x8.5 wheels which work well with the 35x12.5 tires
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#16 |
Resident of Here
You could go with some Ansen Sprints. Made by American Racing now, nice vintage wheel.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
