Old 04-13-2011, 10:47 PM   #1
jsmithbm
jsmithbm's Avatar
1970 brake upgrade question
Hey guys, i've got a 70 swb stepside. Im looking to upgrade the front brakes to disc. I've read several previous post on here. But i wanted a straight answer on this topic.
1- What is needed to put disk brakes on the front?
2- will a 71 knuckle/spindle fit in the upper and lower control arms?
3- i have a power brake booster, do i need to run new steel lines?
thanks
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 04-13-2011, 11:12 PM   #2
jsmithbm
jsmithbm's Avatar
Re: 1970 brake upgrade question
i was going to buy most of the stuff from a/m store like oreillys instead of pulling the old stuff.
Learning as I go!
Old 04-14-2011, 09:41 AM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
have you read thru this thread??....Lots of great info to answer you questions in #1
http://67-72chevytrucks.com/vboard/s...d.php?t=444815
#2 yes the spindle will fit, but you'll need to change the ball joints and tie rods and center link
#3 does your truck already have power brakes or are you adding....if adding, you'll probably have to re-plumb some of the lines
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-15-2011, 08:42 PM   #4
jsmithbm
jsmithbm's Avatar
thanks, i re read the post on the faq.
Learning as I go!
