Old 04-13-2011, 10:58 PM   #1
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
THATS NOT SUPPOSED TO BE ON!!!! wiring help
Okay, tonight......took cluster out, replaced all the gauges with new ones, replaced the printed circuit, replaced lights + light sockets, wiper switch and headlight switch....then turned on the headlights to test....guess what happened...my headlights came on but so did my right turn signal...and the column was in the "middle" position....turned signal to right....the light goes off....turned it to left...light came back on (both times it was constantly on)...put key in ignition and turned ignition on....right signal light came on constant....put switch on right turn and the light started blinking...turned on middle...constant....turned on left...and it goes off but the left doesn't turn on and the front turn lights were off time (blinked at different times)...I know I put everything in correctly because I checked everything...does anyone know what could be going on???
Pic...ignition off and on middle position
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
