new clutch noise.HELP
installed a new clutch in the 72 c10 v8 350. the truck wont go into gear from a dead stop in neutral. and when in gear ther is a noise, alomst like a vaccum leak or something but only when the truck is in gear. b4 the new clutch , it wouldnt go into gear from a dead stop but did NOT make the noise. im so frustrated with the darn thing. havent had her on the road 4 a month. any help would be greatly appreciated. thanks guys
Restoration Virgin!
Re: new clutch noise.HELP
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Active Member
![]() Join Date: Jul 2007
I'm confused. Probably need to explain the problem a little better.. When you say it "won't go into gear from a dead stop in neutral" do you mean it jams or is it hard to shift into first gear? The reason I ask is because you also say it makes a noise when in gear. How do you manage to get it into gear?
Questions: Did you replace the throwout bearing/pressure plate also? The noise may be a worn throwout bearing or if it's new, a defective one. If you also replaced the pressure plate, I've had to replace brand new ones before because they wouldn't release properly. But, the first thing you need to check is clutch play and link arm adjustment and insure you have tight rubber inserts in all of the link arm holes. |
what its TTT???
68gmsee. well the only way i can get her into gear is to start her in gear. but when i have her in neutral and start her up there is no noise. but when i start her in gear ther is a noise like a vaccum leak. i replaced everything. t.o. bearing, pilot bearing, clutch disk, pressure plate. i was thinking the linkage also. but i been under the weather and havent had the drive to work on her. spring is in full bloom here in AZ so my allergies triggered a head cold. again. thanks 4 the help guys! it is much appreciated! |
Restoration Virgin!
ttt=to the top....brings your thread back to the top of the board for more exposure
how do you do such a thing?
Tags |
clutch noise |
