Old 04-14-2011, 12:43 AM   #1
sduckworth13
sduckworth13's Avatar
What offset size rim will I need to use on a 4/6 drop
I have read so many different combos, I'm now lost in what works great. What offset should I use if I want a 4/6 drop on my 1967 GMC 3/4. I have suspension from a 1974 Chevy 1/2 ton donor truck, I'm installing a 5 lug disc/drum setup. I'm doing a almost complete swap of the frontend except the crossmember and I'm going to use the rearend out of the 1974 Chevy 1/2 ton truck also. What drop kit gives the best ride and is a reasonably price kit. I know that the 1974 suspension is wider in front and back. What would be the best offset to use with 20 inch rims or 22 inch rims?
sduckworth13 is offline   Reply With Quote
Old 04-14-2011, 12:09 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: What offset size rim will I need to use on a 4/6 drop
What width wheels are you planning on using?
20x8?
20x9?
20x10?
Better yet,... which wheels exactly?
Most wheels only come is a few backspaces.
I recommend ECE's 4.5/6 drop.
Keith
Convert to disc brakes.
Old 04-14-2011, 10:32 PM   #3
sduckworth13
Keith, I'm needing advice on all the above. I don't know what width or size of rim that will be the best choice. I'm open to using any rim. I might have missed it, but I looked at ECE for a drop 4/6 for a 1974 Chevy Truck. I didn't see they carried it.
Thanks,
Scott
Old 04-14-2011, 10:54 PM   #4
SCOTI
SCOTI's Avatar
Thanks,
Scott
You'll need a 4/6 kit for a 67 w/leaf rear (assuming your 3/4 ton is leaf suspension) & a disc conversion. If it has coils, you want the 4/6 drop for 67 1/2 ton w/coil suspension.
For a staggered set-up, 20x8's up front w/4.5 to 5.25" back-spacing (I prefer 5-5.25" personally). Use a 255-40-20 (28" tall). 20x9.5's w/5.0" back spacing & a 275-45-20 or 20x10's 5/5.5" back spacing & 295-40-20's (29.3" tall).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-14-2011, 11:16 PM   #5
sduckworth13
Even though I'm using a 1974 Chevy 1/2 ton suspension ( disc/ drum ), I still need to get a 4/6 drop for a 1967 w/ leafs? I don't have coils, leafs only.
Old 04-14-2011, 11:29 PM   #6
sduckworth13
Thanks for the info on the drop kit and the wheels
Old 04-14-2011, 11:40 PM   #7
SCOTI
SCOTI's Avatar
You just need to specify (clarify) that it's a 67 that was converted to disc brakes using 73-80 parts donor & the rear housing came from the same donor.
You'll need 73-80 dropped spindles & a drop coil for a 67-72.
The 67-72 rear leafs utilize different hangers, shackles, & narrower leafs (2.25" vs. 2.5"). You'll want a flip kit for the 67-72 year model. The 67-72 & 73-80 rear axle housings utilize the same OD axle tubes, they were just different lengths (67-70 shorter; 71-87 longer).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-14-2011, 11:44 PM   #8
sduckworth13
cool, thanks for clearing that up, appreciate the help. Thats really helpful, now I might sound like I know what I'm doing when I buy the parts.
Thanks,
Scott
Old 04-14-2011, 11:55 PM   #9
SCOTI
SCOTI's Avatar
Is your plan to use the original leafs or the leafs from the donor?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-15-2011, 12:00 AM   #10
sduckworth13
I'm going to use my original leafs for now, I was inform to do it that way. I had the guy I bought the rearend from cut off the 1974 Chevy donor truck leafs.
Old 04-15-2011, 12:01 AM   #11
sduckworth13
I was wondering if I should do a flip kit of lower leafs on the rear, or is there a better option for my set up.
Old 04-15-2011, 12:20 AM   #12
SCOTI
SCOTI's Avatar
For 6" drop? Flip kit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-15-2011, 12:24 AM   #13
sduckworth13
Ok, thank you.
