Old 04-14-2011, 07:59 AM   #1
tbrown5079
driveshaft to mate 4L60 trans to older 10 bolt
With the Ls engine installed and the 10 bolt from a 69 Chevelle what is a good driveshaft to start with? One end will need to be changed to fit the old to the new won't it? Anybody do this?
tbrown5079 is offline   Reply With Quote
Old 04-14-2011, 10:11 AM   #2
Dan Bowles
AD Addict
Re: driveshaft to mate 4L60 trans to older 10 bolt
I used a NV3500 in our truck. A local shop cut down a late model Chevy truck aluminum shaft based on my measurements and swapped in a new adaptor type U joints and I was off and running in 24 hours. $200.
Dan Bowles is offline   Reply With Quote
Old 04-14-2011, 07:15 PM   #3
mr48chev
mr48chev's Avatar
That rear end should call for a 1310 spicer U joint which is pretty common in a lot of vehicles.
The front yoke would depend on which transmission you put in along with the engine and the size an spline count of the yoke for the drive shaft.
Length depends on where you set the engine in as everyone seems to do it just a bit different and even with the same engines transmissons and rear ends the driveshaft length might not be the same in two really similar trucks.
I cheat and go to my buddy's house and dig in the apple bins full of old driveshafts he has stashed out back. But if you figure out the length you need lots of wrecking yards have driveshaft piles The other option is to haul the truck to a driveshaft and have them build you a new one.
