04-14-2011, 08:17 AM | #1 |
Upper Ball Joint Torque??
First off a HUGE shout out to Hot Trucks yesterday for personally calling me and walking me through the job. What tremendous act of kindness.
Anyway, do the top four bolts have a torque setting because you can move the ball stud around before tightening them so I am assuming torque is a big deal here and I forgot to ask. Last edited by ubtripn; 04-14-2011 at 08:29 AM. |
04-15-2011, 06:22 AM | #2 |
67-72 parts collector,…
Re: Upper Ball Joint Torque??
Usually your instructions (that came with your new balljoint) have a torque spec for that specific brand of ball joint.
04-15-2011, 06:24 AM | #3 |
Also,... the castle nut torque for the upper ball joint stud is 50 ft. lbs.
90 ft. lbs. for the lower ball joint.
04-15-2011, 06:32 AM | #4 |
Watch out for your cornhole !
If I remember right, they're 3/8 bolts so shoot for mid 30s ft/lb range.
The four ball joint mount bolts won't affect the ball stud moving around though.
04-15-2011, 06:33 AM | #5 |
Redefining LowBudget
Told yea to call if you had any other ???'s
if your talking about the little bolts that hold the joint to the a arm make them tight.....lmao I have a torque wrench but tend to do things by feel..... also I feel like an AssHat......I should have told you want an old wrench told me years ago.. " Put never seize on everything you work on you never know who the next jackass to work on is going to be.....it maybe you!!" thank Lolife |
04-15-2011, 10:28 PM | #6 |
I know, I just didn't want to bug ya again, you really saved my butt by walking me through it. Thanks again man, I could not have done it without you and thank you to the board.
(I remembered the anti-seize and even set the alignment like you said, worked beautifully.) |
