03-24-2003, 09:00 PM | #1 |
WHYBYNU when old will do
Vac. line ?
I just pulled my gauge cluster out to put in a new oil gauge and I found a vac-line under the dash and it's not hooked to anything.
I follow it through the firewall and the other end is plugged in to left b (1406 Edel.) What should it be plugged into? Here is a pic of the line I'm talking about.. Thanks John
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
03-24-2003, 09:03 PM | #2 |
no pic
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
03-24-2003, 09:46 PM | #3 |
Old member
Gauge
I would assume some time or another there was a vacuum gauge hoked up at some point in the truck. It is used for gas milage.
