Old 04-14-2011, 11:18 AM   #1
michael bustamante
michael bustamante's Avatar
airride compressor problems
ok I have a thomas compressor thats supposed to be 150. psi. it turns on and runs but is not pushing any air. is there a rebuid kit for these things or should I replace? if so whats a good compressor? i know viair of course but I dont need a fancy chrome one. does viair have their c series in black? or a regular finish? are firestone compresssoras good ones?
1967custom
michael bustamante is offline   Reply With Quote
Old 04-15-2011, 06:16 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: airride compressor problems
I would contact our board vendors, in the "Suspension Marketplace".
They seem to be very knowledgeable on these subjects.
I'm going to use a pair of the Viair 400's on my next bagged truck.
Member way2lo2 has an April Special going on right now.
He can fix you up with whatever you need, for a great price.
Keith
Convert to disc brakes.
Old 04-25-2011, 12:08 PM   #3
michael bustamante
hey guys I got a hold of one of our sellers, way2lo2 and he hooked me up good with a viair. Id like to recommend this guy!!
1967custom
Old 04-27-2011, 02:24 PM   #4
tech@scottshotrods
if it is infact the thomas 327 from air ride a 1.00 reed valve will fix the problem..
if you need a new compressor We are offering unbeatable deals on viair right now
tech@scottshotrods is offline   Reply With Quote
Old 04-30-2011, 02:14 AM   #5
michael bustamante
What's a reed valve? Would kneed to rebuild it to replace the reed?
1967custom
Old 05-02-2011, 11:11 AM   #6
tech@scottshotrods
on the black thomas compressor there is a reed valve that seats inside the compressor head, some times they lose there tension and will go bad which will cause air to leak back through the compressor head and not build pressure. to replace the reed all you have to do is remove the (4) bolts from the top of the compressor head, remove the top portion of the compressor head, then you will see the reed valve which is a flat metal flap held down by (1) screw, remove the screw, replace reed and you are good to go....
Old 05-02-2011, 03:34 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Sounds pretty simple Jon. Where would be the best source for the reed valve?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
