Old 04-14-2011, 02:03 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
Bellhousing question
Are the truck bellhousings the same for a Saginaw and an SM465??? I have a line one and want to see if it's a good deal..........
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 04-15-2011, 08:36 AM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Bellhousing question
The input bearing retainer diameter is larger on the truck transmissions, so the only way you can use a car transmission with a truck bell housing is to have an adapter ring made to reduce the hole in the truck bell to the size of the input bearing retainer on the car trans. I found a guy on the chevelle forums that makes these rings and got mine from him, I'll see if I can find his contact info.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-15-2011, 04:36 PM   #3
ECU PIRATE
ECU PIRATE's Avatar
Thanks man. I probably should have clarified my request a little better. I am trying to find out if the truck bellhousing that came with a 3 spd Saginaw in our trucks, is teh same as the bell that came in a truck with and SM465? This is for my new project " Miss Callie Mae ". You already know that I am using the aluminum bellhousing out of my 68' Camaro wiht my Muncie. How is the truck coming along?
The Fleet........
Old 04-24-2011, 08:31 AM   #4
ECU PIRATE
ECU PIRATE's Avatar
Am I going to be able to use my car bellhousing out of my camaro or will I be forced ti use the truck bell housing? I just had my 153 tooth flywheel resurfaced and already have a brand new hays clutch set up with a 10.4" Clutch. The difference really seems like the block mounted bell crank pivot ball for the car transmission versus the bell housing mounted bell crank pivot on the truck bellhousing.....happy Easter fellas!!!!
The Fleet........
Old 04-25-2011, 09:37 AM   #5
swb85
swb85's Avatar
Long as your block has the provisions for the pivot then you're fine. In fact I think all blocks at least had the pedestal for it, just not all were drilled/tapped. You may have to move the z-bar bracket forward on the frame to line the linkage back up though, and that would require a longer link between the clutch pedal and the z-bar......would be a good time to upgrade to an adjustable rod end type link instead of the old stock stuff that gets wallered out over time.
