how does my carb linkage hook up??
the process of instaling my 383 into my k10 67 is done, i just need to start hooking everything up. the truck had a 292 6 cyl in it and now my carb is a holley. so i dont know if this tells you anything... the truck just has the little arm coming off the firewall and the carb just has some holes ior somting it looks like for the thing, do i need to purchase somthing?? or anyone got somthing i can buy from them on here? thanks guys
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
I swapped a 6 cyl to 8 cyl 350 a few years back. What you need is a threaded rod with two (or the same thing) on both ends. I don't know what they call them, bought mine from NAPA. The are female and thread onto the rod.. They have a swivel that bolts onto carb and pedal arm (90 degrees). U should be able to find something from autoparts store or summit.com.
Good luck!
67 Fleetside Shortie, small window, slip & slide tranny Upgrades--small block, tilt column, disc 5 lug conversion (front and rear), Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG) |
thanks a lot ill keep my eye out
matt
Fabricate till you "puke"
Rod ends are the pcs you are looking for. If you look under chassis parts in the Summit racing site , you will find them. You can also slip a pc of tubing over the threaded rod to give it a smooth look.......crazyL
