what will it do?
so the guy who is gonna build my motor is more or less building the same motor he had in a 67-69 camaro that went 6.7..... in the 8th. knowing him Im sure it was a caged lighted up a bit mostly 99%race, street car. so the question is almost the same motor what will it do in my truck. its a 406 solid roller aluminum heads 11 to 1 compression about low 500 hp. with a richmond gear 6 speed and nitto nto5 tires. I know getting off the line will suck but any one got a guess
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 Last edited by jus2qwk; 04-14-2011 at 07:31 PM. |
Re: what will it do?
Hard to compare with out more info on the other car. Weight and 60' info would help.
My guess, mid-high 11's..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
It ought to be fun
![]() Mid 11's after you figure out how to launch it...shift it and keep the tranny in it. Don't let the ET deter you though, your's sounds more of a cruiser than a drag racer.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
low 12's
that 6 spd doesn't like powershifts.. you shouldn't need 11 to 1 to get 500hp out of a 406 what heads and cam he use'n remember the heads and cam that "he" used in his "light camaro" will not work the same in a 2 ton truck |
"Where were you in '62?"
![]() Join Date: Jul 2004
Weighs some where 3700lbs stock I think.....
![]() ET Calculators: http://www.wallaceracing.com/et-hp-mph.php http://www.race-cars.net/calculators/et_calculator.html http://www.google.com/search?q=hp+et...9918eb06677aa8
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
I know my old 01 SS camaro with just headers, tune, ported stock throttle mody, K&N filter, Fast toys Ram air and ported MAF ends went 12.44 @ 109 with 335rwhp and 3,600lbs with a 1.99 60'. You have a lot more power but a lot less aero. I don't see any reason it won't dip in the mid-high 11's..
#7 | |
your hp is at the wheel; his the crank.. he might have 30-40hp on you and no aero |
I really dont know that much about the camaro but the guy has been racing forever and be building 400s about as long, he had a 73 nova I think with basically stock suspension running in the 5.7 index class. but as far as my truck goes it is for sure a cruiser that I wanna take to the strip once or twice a year and be able to run a fairly good time. I would be more than happy if I could run a mid 7 in the 8th
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 Last edited by jus2qwk; 04-16-2011 at 09:50 AM. |
I disagree. For example my buddies 418ci SBC made 424rwhp through a TH400, 9" with loose stall and ran 6.9x/10.8x NA with a 1.55 60' in a 63 nova wagon weighing aprox 3,000lbs with driver (He did swap to an electric water pump and powerglide after the dyno and before the ET's mentioned which I know would move rwhp numbers up). That seems somewhat comparable to the motor/car mentioned that this motor is being based on. That motor is making more than 375rwhp to go 6.7x in a 1st gen camaro. We are talking about a car that should be running 10.4-10.5 in the quarter.
I don't know about the Richmond 6 speeds, but I know the T56's rob about 15% power. If it makes > 500 crank hp, it should still be making > 425rwhp.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 04-16-2011 at 02:05 PM. |
