Tie down anchors/rings?
Hi,
Which tie down anchors/rings are you guys using? I found these on LMC: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=28 Do you think those are safe to use? Will too much weight on the anchors cause them to slip out of the hole?
Thanks, Emil 1972 Chevy C20 |
BlahBlahBlah
Re: Tie down anchors/rings?
Ive used those before. Not super strong in my book. I never trusted them for any thing heavy duty.
I see, so how do you recommend we use tie straps? Just hook them into the existing holes?
![]() Join Date: Feb 2011
I got some pop-up ones at Harbor Freight for around $10 a pair. I had to trim down the inner mounting plate, but they seem to work well:
http://www.harborfreight.com/pack-of...ors-93170.html Posted via Mobile Device |
Between Trucks...
I have the chrome ones from LMC. They work O.K. for loads of wood and stuff like that.
Beat it to fit, Paint it to match... ![]() |
![]() Join Date: Mar 2010
http://67-72chevytrucks.com/vboard/s...d.php?t=393584
This thread shows some tie down options under the rail using existing holes (slightly modified). I used an option like this and it is super strong and out of the way.
1969 Chevy K20 Longbed |
Redefining LowBudget
I removed 4 bolts in the corners of the bed that go though the floor supports....I then got 4 eye bolts and welded them closed so they can't staighten out ( and they will ) I tie down 800 lb dressed harleys in the back alot ( matter a fact I'm moving one tonight) never had an issue....I also tie down my slide in camper to these rings.... being bagged I can dump the tailgate down to about 10" off the ground drive thenm in air up and go.....
