Old 03-24-2003, 10:03 PM   #1
orange72350
orange72350's Avatar
Stall Converter????
I've been reading magazines, and trying to figure out what a stall converter is. Could anybody tell me exactly what they are and what they do. Please??????? I would really like 2 know this little tidbit of info. thanx
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 03-24-2003, 10:18 PM   #2
Low69CST
has to do with how fast your engine revs before it fully engages the transmission. High stalls are used to let rough cam engines idle without dragging the motor and to give drag cars a better launch. Not many people know, just what i've learned through a few articles
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-25-2003, 12:36 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And to go a little more basic, it is located at the front of your tranny, and bolts to the flex plate(flywheel) ont eh engine. This item has (basicly) 2 fans in it, one driven by the engine, and the other facing the first, and driven from the rushing fluid. (place 2 indow fans one facing the other. Turn one on... the other will start to turn from the air moving through the blades)
This is the simplified explination of a torque converter. This way, you can keep it in gear with the engine running, and come to a complete stop without stalling the engine.
As stated above, a higher stall torque converter will alow you to bring the RPMs up more as you take off. Much like when you are driving a stick. If you want to take off fast in a 4 speed, you rev the eninge higher as you let the clutch out.
However, this is one thing that is more of a science, and if your thinking of getting an aftermarked unit, call the pros (like TCI) and have your vehicle weight, tire size, tranny type, rear gear ration, and engine specs on hand so they can sell you the right one.
The less you know about all those things and how they work together, the more important it is to call someone who does. If you get the wrong torque converter, your ride wil most likely be a dog and feel real 'slushey'.
