04-15-2011, 11:19 AM | #1 |
Oil pan removal question
I have a 1972 GMC Sierra 1/2 ton with stock 350/350.
I need to reseal the timing chain and oil pan, can the oil pan be removed with the engine in the truck? Looks like it's pretty tight fit between the front cross memeber at the oil pan. This is my faily driver right now so I don't want to get half way into the job and realize I'm screwed! Going to replace the timing gears/chain and oil pump while I"m in there, who knows how old the ones in there are! Thanks
1972 GMC Sierra LWB (Aquafresh) 1962 Cadillac Convertible 1962 Cadillac Sedan project |
04-15-2011, 11:37 AM | #2 | |
Re: Oil pan removal question
04-15-2011, 11:42 AM | #3 |
You don't have to pull the motor. What I did was unbolt the motor mounts and jack the engine up a few inches, then insert 2x4 blocks between the mounts and frame to hold the engine up a few inches. More than enough room to get the job done, and lots quicker than pulling the whole thing out.
04-15-2011, 04:03 PM | #4 |
Thanks, there is no way I'm going to pull it out. I do have a cherry picker I could lift it up with though.
04-15-2011, 04:22 PM | #5 | |
i've found it works better with using a 1/4 drive ratchet and especcially a long extension in the deep part of the pan
04-15-2011, 07:45 PM | #6 |
I don't want to steal this thread, but i have to change my oil pan gasket to. I have a 350 engine in my 68 ( was a six cyl. ). This winter put new motor mounts in using a cherry picker, it was very tight. If i took out the distribitor and did the same above would that give me the room? Thanks...Russ
04-15-2011, 08:06 PM | #7 | |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-16-2011, 11:14 AM | #8 |
Once again thanks for helping with the information VetteVet.....Russ
04-16-2011, 03:30 PM | #9 |
454 MAKES IT ROAR
I know this is the way to do this...BUT! where abouts are you guys putting the jack? crossmember is in the way, can't jack from the pan for obvious reasons, so all's left as far as I can tell is the bottom of the Harmonic Balancer.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
04-16-2011, 04:18 PM | #10 | ||
"I ain't nobody, dork."
Not using a jack from below... using a cherry picker from above.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
