04-15-2011, 12:00 PM | #1 |
Not too old to learn
How to paint white cab top ?
What I really need is pictures of cab tops in white.
Where are the separation lines both inside the door frame and the back of cab ? I figure the A pillar will be painted white also. My truck is a 68 and is solid color now so I have no reference points to go by. I will need to add the chrome strip under rear glass, so need to see where the color line will be. Thanks.
1968 C10 a way to long restoration. |
04-15-2011, 12:54 PM | #2 |
Re: How to paint white cab top ?
I painted the window frame white on my door. Then I simply put a tape line down even with that all the way around the back.
I didn't add the chrome strip. I was going to put a piece of trip tape over the line but so far haven't bothered. The a-pillars I painted white too.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-15-2011, 05:18 PM | #4 |
Here are some photos of my family 68 two-tone with original paint, FWIW.
04-15-2011, 05:28 PM | #5 |
The stock paint on my 67 is only to the drip rail, no door or A-pilar. Don't have a better / closer pic.
Brad 67 Chevy SWB stepside - http://67-72chevytrucks.com/vboard/s...d.php?t=449426 89 Ford Bronco 92 Suzuki Sidekick 94 Kawasaki Vulcan 750 06 Honda Aquatrax |
04-15-2011, 05:51 PM | #6 |
67 was painted differently than 69-72 , not sure about 68.
72 Cheyenne Super 80 Silverado Blazer 2wd |
04-15-2011, 06:02 PM | #7 |
04-15-2011, 06:06 PM | #8 |
Looks like a 68 was painted like the 67 with the pillar and door frame not white. I guess if you are not going for a 100 % correct truck you can paint it like the 69-72 tops.
04-15-2011, 06:21 PM | #9 | |
http://www.67-72chevytrucks.com/vboa...d.php?t=143327 http://67-72chevytrucks.com/vboard/s...d.php?t=346534 |
04-15-2011, 06:41 PM | #10 |
I was thinking that 68 was like 69-72, but I was going by this old 68 GMC original paint we had awhile back. I think I will just stay out of this debate.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 04-15-2011 at 06:41 PM. |
04-15-2011, 08:06 PM | #11 |
Good info from all, now I can proceed except for one more question.
The white color code ?
04-15-2011, 09:19 PM | #12 |
Samey,
Maybe it was different for GMCs? Or there was some of both? Anyway, I like the truck. |
04-15-2011, 09:49 PM | #13 |
on my 71 GMC burb all pillers exept the d-piller witch is white look like they used the drip rail as the break
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
04-15-2011, 10:04 PM | #14 |
i didnt paint the door frames or A pillars on mine.
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
04-16-2011, 02:22 PM | #15 |
BLACK SATIN
you can look in my album if you need any more. I am a fan of white tops, too.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci |
04-16-2011, 06:17 PM | #16 | |
White 521 DuPont 817-L Rinshed-Mason A-1347 Ditzler DQE-8080 Good Luck! Keith Last edited by lil hoodlum; 04-16-2011 at 06:18 PM. Reason: misspell |
04-16-2011, 06:28 PM | #17 |
Thanks Keith.
