04-15-2011, 12:21 PM | #1 |
New truck
I have oil on my starter, and all over the oil pan in front of the rear main. The rear main does not seam to be leaking. The drivers side valve cover is leaking, but the passenger side is not. Could the oil be going from the drivers side to the passenger side. I plan to replace the gaskets. Thanks.
04-15-2011, 12:35 PM | #2 |
GM Parts Guy
Re: New truck
It's possible. If your wondering where it's coming from clean off all the oil, and put some tracer dye in the oil. Then using a blacklight, you'll be able to see exactly where it's coming from.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
04-15-2011, 01:33 PM | #3 |
Arrived on a Pale Horse
Re: New truck
Have you checked the gauge pressure sending unit behind the distributor?
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
04-15-2011, 10:23 PM | #4 |
Re: New truck
I checked the sender unit. It was wet. I wiped it off. I will replace the valve covers, and then check it for leaks again. Thanks.
