Old 04-15-2011, 01:18 PM   #1
Puglia10
Helper bags and cal-tracs?
Trying to figure out my rear suspension set up as I put the frame back together. I have a Flip kit with 3 leafs, few questions. With the 6.0 I'd like to have cal-tracs for traction, but helper bags for hauling the dirt bikes. Is that possible with a flip kit? And who makes a good helper bag kit?
Thanks!
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 04-15-2011, 05:44 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Helper bags and cal-tracs?
I would think with the helper bags you could preload the suspension and you wouldn't need the cal tracks? Just a thought.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-15-2011, 08:07 PM   #3
Puglia10
Hmmm never thought of that. Anyone know if that works? Or any other help? Thanks!
1979 c30 3+3 dually
1946 GMC
Old 04-15-2011, 11:02 PM   #4
SCOTI
SCOTI's Avatar
Not exactly.... He'll need something to counter the minimum qty of leafs. The fewer the leafs in the spring pack, the worse axle hop will be. But.... yes, air bags could help tune an existing set-up by adjusting pre-load.
If it were mine & I was trying to accomplish a quick part-time track truck that can still carry some payload, I'd skip the flipped leafs w/the helper bag & do it right w/a 4-bar.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-16-2011, 01:07 PM   #5
Puglia10
I actually have a 4link from KP that I was planning on selling since I can't find any coilovers that wouldn't kill my budget, but should I rethink that?
1979 c30 3+3 dually
1946 GMC
Old 04-16-2011, 01:38 PM   #6
72MARIO
72MARIO's Avatar
I have Cal-Tracks and full pack of springs minius the overload. There is no reason you could not put a air over leaf on it. Not fully sure if you would need it either.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is online now   Reply With Quote
Old 04-20-2011, 05:12 PM   #7
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I'm running Cal-Tracs with a flipped rear and 3 leafs, but went with what I had at the time, air shocks. Works well enough for a driver that rarely sees anything in the bed.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-20-2011, 06:49 PM   #8
Puglia10
Twisted- how much drop did a flip with 3 leafs get you? How does it ride and handle with that set up? Think helper bags would be overkill? Could you haul two fullsize dirtbikes or one snowmobile okay you think?
1979 c30 3+3 dually
1946 GMC
Old 04-21-2011, 12:15 PM   #9
Twisted78SS
Wide n'Low
Puglia10,
I am running right at 6.5 inches from the stock height in the rear. Currently I am running a 275/60x15 tire at 28 inches tall, which put the top of the tire nearly even with the top of the wheel well opening. Here is a shot right after I drug it out of the shop.
Depending on the max pressure of the shocks you run, I don't see why it wouldn't be able to handle a decent load.
So far, I have only been running about 8-10 psi in the shocks, and it seems to like it ok. I really need to c-notch the frame as I have maybe an 1.5 inches between the top of the axle and the frame.
Air Force Retired
Old 04-22-2011, 05:46 PM   #10
Puglia10
Thanks for all the info! Much appreciated...any more pics of that truck would be great, i love how it sits. What is the drop on the front?
1979 c30 3+3 dually
1946 GMC
Old 04-24-2011, 11:23 PM   #11
Twisted78SS
Wide n'Low
There are some more pics here http://www.flickr.com/photos/hikingd...7594445283108/ I will get a few more after I decide on some better wheels..
The front has dropped a-arms and a 2 inch lowered spring. I think the dropped a-arms are about 2 inches to give me a total of 4 inches in the front.
Air Force Retired
