Old 04-15-2011, 01:37 PM   #1
ppbr2001
ppbr2001's Avatar
Fan
My fan actually fell off this morning!! Looks like the clutch came apart.
Any way to bolt it solid with no clutch?
ppbr2001 is offline   Reply With Quote
Old 04-15-2011, 01:42 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Fan
Time to upgrade to electric fan. Non clutch/flex fans are too dangerous IMHO.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-15-2011, 02:39 PM   #3
78 Chevyrado
Re: Fan
Just buy another clutch, unless you go electric.
The clutch will give you (SAP LESS) more power and economy then anything but an electric fan. It can be done, but you'd be downgrading a lot.
78 Chevyrado is offline   Reply With Quote
Old 04-15-2011, 10:35 PM   #4
ppbr2001
ppbr2001's Avatar
Re: Fan
Didn't go thru the radiator at least!
Old 04-18-2011, 07:35 AM   #5
ppbr2001
ppbr2001's Avatar
Re: Fan
24.00 for a clutch and 99.00 for electric. That is soooo tempting!
Old 04-18-2011, 10:44 AM   #6
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
Re: Fan
Dude, get on Ebay or go to a junk yard and get a Ford Taurus Fan. They are cheap, work amazing, and easy to install.
West Texas Z is offline   Reply With Quote
Old 04-18-2011, 11:02 AM   #7
jchav62
1962 C-10
jchav62's Avatar
Re: Fan
I prefer clutch fans. I got mine from the junkyard... very cheap.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-18-2011, 11:28 AM   #8
sumran
sumran's Avatar
Re: Fan
Pictures, additional info or a link if you would be so kind.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 04-18-2011, 11:55 AM   #9
wyattglock
wyattglock's Avatar
Re: Fan
Do a clutch fan with an auxiliary electric. Works really good when towing while its hot out.
wyattglock is offline   Reply With Quote
Old 04-18-2011, 06:46 PM   #10
West Texas Z
Re: Fan
http://cgi.ebay.com/ebaymotors/94-Fo...Q5fAccessories
This is the fan I use. Its easy to mount and wire up with a Autozone Universal fan kit. I did the whole swap for under $50.00 I think. I recommend it one hundred percent. I like that is thin and pulls air like crazy. Do it. lol
Old 04-18-2011, 07:30 PM   #11
tucsonjwt
Re: Fan
I don't like electric fans for two reasons:
1) If they are temperature controlled they rely on a temp sensor which is another gizmo to make me wonder if he fan is really turning on at the correct time.
2) If they are on all the time they are a hp/fuel drain on the vehicle.
The radiator repair guys I have talked to about them have always recommended the stock fan/clutch setup on American vehicles that had them.
If you have a high horse vehicle, then an electric fan makes sense as a secondary fan.
I have an 83 C20 454 in the hottest place in the world and the stock clutch fan has not caused any cooling problem in the past 8 years.
Is it possible for your truck to be "too cool" - I don't mean too cool looking but to cool in temperature?
tucsonjwt is offline   Reply With Quote
Old 04-18-2011, 07:39 PM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Fan
You live in hot climate. Better read this http://www.fordmuscle.com/archives/2...cfan/index.php
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-18-2011, 08:14 PM   #13
sumran
sumran's Avatar
Re: Fan
Thanks for the info.
Randy Summers
Old 04-18-2011, 11:23 PM   #14
justinburnett
justinburnett's Avatar
Re: Fan
Someone put a flex fan on my truck before I got it. Damned thing flew apart and chopped up a radiator hose, and then the balance issue must've caused the water pump to come apart somehow because it was leaking out of about 5 places. Bad news. Didn't know better but I do now. Picked up a stock clutch fan for $25 at a yard, and no problem since. Wouldn't mind an aux electric fan, just in case, but I hate trusting some little probably-China-made sensor that may or may not work to keep things cool when it matters. I like to think I check my gauges pretty often, but I can't sit and stare at them the whole time i'm driving to make sure everything is doing it's job. I like big, clunky, mechanical processes where if something's not working it's cause it's split in half or fell off. Easy to see, easy to fix.
justinburnett is offline   Reply With Quote
Old 04-18-2011, 11:36 PM   #15
West Texas Z
Re: Fan
No problem, hope it works for you as it did for me.
Old 04-20-2011, 11:51 PM   #16
ppbr2001
ppbr2001's Avatar
Re: Fan
Traded my old valve covers, air cleaner and exhaust tips for a used fan and clutch. Back on the road again!!
