04-15-2011, 02:48 PM | #1 |
71 cab for patches
This is an ac cab that is missing the driver side cab corner and the roof has holes from aftermarket lights. There should be some good patches remaining.
$25 and up per patch plus shipping. Thanks, Ray |
04-15-2011, 03:10 PM | #2 |
Re: 71 cab for patches
Hey buddy,
What does the rear floor look like? Thanks Rich |
04-15-2011, 04:54 PM | #3 |
It is solid with some surface rust under the seat.
04-15-2011, 05:07 PM | #4 |
How are the rear corners of the floor?
04-15-2011, 05:52 PM | #5 |
The floor in the driver side has been sold a while back, but the passenger is solid. I can also check a 68 cab for the driver floor.
04-15-2011, 06:29 PM | #6 |
How much for the rear window channel cut out and shipped to 53105?
04-15-2011, 06:40 PM | #7 |
VA72C10
Interested in the passenger side cowl where the A/C blower goes all the way to the top
From below the circle, around the entire circle, and to the windshield frame Also the lower cowl area (lower 4") on both sides price to 23112?
Looking for a 67-72 swb or blazer project in or around VA. |
04-15-2011, 07:09 PM | #8 |
I need the corner section from the outside to the jack hold down bracket and from the back to the wire that is pictured. Same on the other side if you have. How much plus shipping to zip 32136? Thanks Projectjimmie
04-15-2011, 07:25 PM | #9 |
VA72C10
I believe Gcburdic and Brn agn are looking for the lower door hinge pillar area (where the lower hinge screws to) on the passenger side....
04-16-2011, 12:02 AM | #10 |
grwnded71- $100 shipped. How many inches from window opening for the cut?
VA72C10- Can you draw your patches on my pics? projectjimmie68- $80 shipped for both sides...I will get the driver side from my 68. Jonathan- Thanks for the lead. I plan on cutting and shipping all patches next week. Thanks, Ray |
04-16-2011, 02:34 AM | #11 |
VA72C10
Here you go. both sides of the lower cowl and the area around the blower as shown.
04-16-2011, 09:53 AM | #12 |
Jonathan, Thanks for the ink! I can send your patches for $70 shipped.
Thanks, Ray |
04-16-2011, 10:14 AM | #13 |
VA72C10
sounds good...can you pm me paypal again and Ill get you paid tonight.
04-16-2011, 10:21 AM | #14 |
pm sent
04-16-2011, 11:35 AM | #15 | |
04-16-2011, 11:59 AM | #16 |
The channel has no rust. pm sent
04-16-2011, 01:09 PM | #17 |
Would you consider shipping the back half of cab floor,(entire floor including the corners that someone else after me got a quote on) to pa.? I am very interested. Thanks, Rich
04-16-2011, 01:31 PM | #18 |
04-16-2011, 06:42 PM | #19 |
Sorry, I lost you in between my posts. I have many cabs that I can get patches from. Part of the driver side floor is already missing on this one. I can do $100 plus greyhound shipping for the rear floor.
Thanks, Ray |
04-16-2011, 07:46 PM | #20 |
Still got me interested. Can you get a shipping quote to York Pa., that is the closest station to me. Thanks. I will go out and get an exact measurement of what I need. Thanks, Rich I need the back 11" of the floor. If cutting with torch cut it where I can drill out spot welds across the back and sides, and keep floor support intact. Thanks, Rich
Last edited by oldschooler; 04-17-2011 at 02:30 PM. Reason: added measurements and cutting instructions |
04-19-2011, 04:54 PM | #21 |
Rich, Its $84 with greyhound. If that works, I will measure 12" from the back wall and cut all the way across the floor and about one inch above the floor on the back wall/corners/door jambs.
Thanks, Ray |
04-19-2011, 04:57 PM | #22 |
Restoration Virgin!
Thanks for remembering Jonathan....but we just got one from Sharpie
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-19-2011, 10:18 PM | #23 |
04-19-2011, 10:26 PM | #24 |
Can I get a better picture of this area?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
04-19-2011, 10:58 PM | #25 |
Jonathan- Here's some pics of your patches.
Mike- Take a look at the pics, however, I carved some of that section already Thanks, Ray |
